How can I copy Bluetooth pairings from a working Raspbian to a fresh installation.
Setting up on each new installation destroys existing pairings.
As part of the procedures I wrote for configuring a fresh installation of Raspbian (now Raspberry Pi OS) I use the following steps to transfer Bluetooth pairings.
Preparation on working Pi
3. Backup Bluetooth
sudo su
tar cf bluePi.tar /var/lib/bluetooth
On a fresh installation of Raspberry Pi OS on the Pi
13 Restore Bluetooth
sudo su
cd /
tar xf /home/pi/bluePi.tar
I have used this to setup Bluetooth from Jessie => Stretch and again from Stretch => Buster
It can also be used to transfer Bluetooth from Raspberry Pi OS (32-bit) with desktop => Raspberry Pi OS (32-bit) Lite which lacks the tools to perform the setup.
I use the SD Card in each of my Pi to setup Bluetooth so I have settings for the Bluetooth controllers on each Pi allowing me to easily transfer SD Card between Pi.
NOTE this does not magically allow Bluetooth devices to be paired to multiple controllers; the normal pairing restrictions apply, but I have a keyboard which can be paired to 3 controllers.
Raspberry Pi OS (32-bit) with desktop => Raspberry Pi OS (32-bit) Litetransfer: Once transferred to the "Lite" host, does Bluetooth operate with the same device (e.g. BT speaker) as was paired with on the "Desktop" machine? I.e. BT spkr namedXYZpaired, connected & operational on "Desktop". After xfer to "Lite" system, will "Lite" also pair, connect & play to spkrXYZ? – Seamus Sep 14 '20 at 00:57bluealsa.service. It certainly works with keyboard & mouse (although there is little point is using a mouse on Lite) – Milliways Sep 14 '20 at 03:58
