I have installed docker on Raspbian Stretch using the install script get-docker.sh, but am having difficulty installing on 64bit Raspbian OS
The install script terminates with
sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
E: Sub-process /usr/bin/dpkg returned an error code (1)
and when I run docker version I get
sudo docker version
Client: Docker Engine - Community
Version: 19.03.12
API version: 1.40
Go version: go1.13.10
Git commit: 48a6621
Built: Mon Jun 22 15:47:06 2020
OS/Arch: linux/arm64
Experimental: false
Cannot connect to the Docker daemon at unix:///var/run/docker.sock.
Is the docker daemon running?
and docker info gives a similar error
Is it one more application that wont run on 64bit? Or have I done something wrong?
