I have a little problem with my Raspberry Pi. I have installed lirc and then I have done the following.
Added
#added for lirc
dtoverlay=gpio-ir,gpio_pin=23
to my /boot/config.txt and changed the /etc/lirc/lirc_options.conf file:
#driver = devinput
#device = auto
driver = default
device = /dev/lirc0
After rebooting i tested it by pressing one button
pi@raspberrypi:/etc/lirc $ mode2 -d /dev/lirc0
Using driver default on device /dev/lirc0
Trying device: /dev/lirc0
Using device: /dev/lirc0
space 16777215
pulse 9127
space 4474
pulse 620
space 517
pulse 616
and many more numbers, so I thought at least that works. But if I try to generate a config file with
irrecord -d /dev/lirc0 ~/lircd.conf only the following file is generated.
begin remote
name cheap_amazon_remote
bits 0
flags CONST_LENGTH
eps 0
aeps 0
one 0 0
zero 0 0
gap 50000
toggle_bit_mask 0x0
frequency 38000
begin codes
KEY_F1 0x0
KEY_F2 0x0
KEY_F3 0x0
KEY_F4 0x0
end codes
end remote
And thats the reason the test with irw only shows KEY_F1 no matter what I press. I don't understand what I did wrong an would be gratefull for any help.
Update
Sadly the Answer from the comments didn't help me. I found this (https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=235256) forum and followed the tutorial, because I also realised that with mode2 I also get a second pulse. Sadly it didn't work. I followed the tutorial until I need to install. It failed as told in the tutorial but with the following error message
Reading package lists... Done
E: Unsupported file ./liblirc0_0.10.1-5.2_armhf.deb given on commandline
E: Unsupported file ./liblircclient0_0.10.1-5.2_armhf.deb given on commandline
E: Unsupported file ./lirc_0.10.1-5.2_armhf.deb given on commandline
Then I tried to do the cp commands but my /etc/lirc folder only has the following content
hardware.conf lircd.conf lircmd.conf
irexec.lircrc lircd.conf.d lirc_options.conf
I don't understand how to fix this or what I did wrong.
Edit
uname -a
Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
