I've installed lighttpd, and it is working fine. I've tried to install php5 as described here, but when I try the last step
sudo service lighttpd force-reload
I get:
[FAIL] Reloading web server configuration: lighttpd failed!
and php is not working.
My lighttpd configuration can be found at http://pastebin.com/eagG4SwF:
server.modules = (
"mod_fastcgi",
"mod_access",
"mod_alias",
"mod_compress",
"mod_redirect",
# "mod_rewrite",
server.document-root = "/mnt/www"
server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
server.errorlog = "/var/log/lighttpd/error.log"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
server.follow-symlink = "enable"
server.dir-listing = "enable"
dir-listing.encoding = "utf-8"
index-file.names = ( "index.php", "index.html", "index.lighttpd.html" )
url.access-deny = ( "~", ".inc" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
# default listening port for IPv6 falls back to the IPv4 port
include_shell "/usr/share/lighttpd/use-ipv6.pl " + server.port
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
