I need to use all five of the PL011 UARTs on a Raspberry Pi 4. I am having no problems with UART2 - UART5. It is only UART0 that is giving me problems.
I connect a serial cable from a laptop to the raspi on UART0, run a terminal on COM1 on the laptop, and I SSH into the raspi and run a terminal (minicom) for "/dev/ttyAMA0". On any other UART when I do this, I can type in either terminal and get the characters echoed on the other terminal. On UART0, however, I get random garble on the raspi side, and I get the string "Minicom2.7.1" echoed repeatedly on the laptop side. If I type in characters on the raspi side, I do see them echoed on the laptop along with the "Minicom" string. What could cause this?
These are the steps I used to enable UART0:
- Disabled bluetooth by adding "dtoverlay=disable-bt" to "/boot/config.txt"
- Setting "enable_uart=1" in the same config file.
- Using raspi-config to enable serial ports and disable the shell over serial
- Disabled the service "hciuart".
The OS is updated with the latest versions of everything.
Also, if I wire the RX to the TX (pin 8 to pin 10) then it behaves as expected, i.e. typing characters into a terminal echoes them back.
Here is part of the output of "raspi-gpio get"
GPIO 14: level=1 fsel=4 alt=0 func=TXD0 pull=NONE
GPIO 15: level=1 fsel=4 alt=0 func=RXD0 pull=UP
There is no func=TXD1 or RXD1. So I am not sure why some people are saying UART 0 and 1 are clashing.
console=tty1part out - leave everything else on one line and reboot. – Aug 25 '20 at 17:52
