I have a 64 GB EVO Select U1 SD Card (link). I ran the Raspberry Pi Diagnostics SD Card Speed test on it. The card always fails the random write test by a large margin (the target speed for this test is 500 IOPS. The test reports usually around 100 IOPS for random writes, and sometimes reports as low as 60 IOPS), and it sometimes fails the sequential write test.
Looking at publicly available performance results that include the EVO Plus, the failure seems unexpected. (Discussions online suggest that it is reasonable to expect similar performance from the EVO Plus and Select cards.)
I see that the log with the test results says that sequential write performance may degrade as the SD card is used, and that reformatting it might help. I had been using this card on a Raspberry Pi 3 Model B+, and I recently installed NOOBS Raspbian GNU/Linux 10 (buster) on the card using the Raspberry Pi Imager to use it on my new Raspberry Pi 4. I assume that using the Imager reformatted the card, but I can't confirm this from research for sure.
Do you have any suggestions about why the SD card might be failing the test?
