Currently I am working on RPI GPIO with a breadboard, some LED's and buttons. My next step is to add a bigger button and LED to de GPIO.
I would like to connect an Eaton 216557 LED-module to the GPIO pins of the Raspberry Pi to control it with a python script.
Specs of the LED-module:
Rated operational voltage [Ue]: 12 - 30 V AC/DC, 50/60 Hz V
Rated operational current [Ie ]: 8 - 15 mA
Power consumption [Pmax.]: 0.26 W
Can someone please tell me if this is possible (since RPI is only 3.3V). If it is possible, how can I get it working?
  • what kind of resistors
  • maybe someone can draw a schematic
  • read something about MOSFET ?
Thanks for helping!
The direct way would be something like this:
This will work for most purposes. With these currents, you can probably use a 2N3904.
If your power consumption is larger, you may want to look at relais cards.
Or for breadboard users:
Ljm Dullaart
  • 2,491
    Is is possible for you to draw a schematic like this for me?: https://i.stack.imgur.com/o0pWb.png
    An 2N3904 basicly 'connects' the + and - based on the input on the 3th pin?
    – Tobias van den Berg Aug 17 '20 at 17:18
