So there is support for Open GL ES 3.1, but how can I use it on the Raspberry Pi 4? Is there any other way to use the GPU for calculations such as fft and logarithm?
I have the exact same question, except that I'm looking to do image processing in the Videocore. But I can't find anything. Did you end up finding something? – gromain Mar 18 '21 at 21:33
1Sorry, but not really. The only thing I found is related to the MESA graphics library but I haven't researched it any further. – Hneggbrand May 06 '21 at 17:28
Check for the boot partition. There you can find many overlays. Try using them. And install mesa gl driver. Then you can activate them from raspi-config
- 1,828
- 10
- 40
The RPi4 has an experimental Opengl "fake" kms driver, but I haven't found a good method to use the API to program for it. – Hneggbrand Aug 19 '20 at 13:37
This answer is quite useless I'm afraid to say. You could have posted just a bit more information about what to look for to ease the pain for others.
So, in there ( https://github.com/raspberrypi/linux/blob/rpi-5.4.y/arch/arm/boot/dts/overlays/README ), look for overlays starting with
– gromain Mar 18 '21 at 21:29vc4. However those seems to be related to display drivers, so they may not do what @Hneggbrand is looking for.
You might like to look at Pete Warden's work using Deep Learning for image recognition with the RPi's GPU here. If you want to code using the GPU have a look at QPILib which is an astonishing piece of work building a language to code on to the Rpi's GPU using only C++'s macro language.
QPULib is a programming language and compiler for the Raspberry Pi's Quad Processing Units (QPUs). It is implemented as a C++ library that runs on the Pi's ARM CPU, generating and offloading programs to the QPUs at runtime.
- 776
- 4
- 15
3These work with Videocore IV as do all the others I have seen, while the RPi4 has the newer Videocore VI graphics chip. – Hneggbrand Aug 19 '20 at 13:36
