The problem:
- I am trying to use a RW1820 (DS18B20), to display the temperature. yet it does not show up in devices. Only w1_bus_master 1 appears.
Setup:
- Raspberry Pi 4
 - 1-Wire Temperature Sensor Module – RW1820 (DS18B20)
Wiresetup:
- Ground to pin 9 (pin 6 is in use due to a cooling fan)
 - Data to Gpio4 (pin 7)
 - VCC to pin 2
Steps I took:
- I found this question by someone who had the same issue but the solution I had already configured correctly. (DS18B20 not listed in /sys/bus/w1/devices)
Things I tried:
- Connected the DS18b20 to my Arduino, sensor worked.
 - Used the same cables I used with the arduino for connecting to the Rpi, cables are okay.
 - Tried using the sensor on 3.3v, no effect
 - Inside the config.txt, I cut and pasted dtoverlay=w1-gpio on multiple lines (made sure only one was uncommented), no effect.
Config content:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display's size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
Additional overlays and parameters are documented /boot/overlays/README
Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
dtoverlay=w1-gpio
Who has any idea what is going wrong? Could one of my GPIO pins be broken?
