So have an issue getting the Raspberry Pi 4 (running the new Buster image) from releasing my eth0 interface to get an IP. It works fine with the wifi, but I'm not sure what I'm doing wrong?
My router is setup to use the RPi as a Pihole/Unbound server and the router itself has all the MAC addresses (the RPi included) assigned to a static local IP successfully. I have noticed under ipconfig (below) there's no ivp4 address like there is for the wlan0?
I've tried setting the eth0 manually to no avail, and also 'sudo update-rc.d dhcpcd disable' but that makes both network interfaces unusable until I enable it. If I hover my mouse over the taskbar it says 'eth0 link up: configuring'. My settings are as follows and any advice would be appreciated:
cat /etc/network/interfaces
Please note that this file is written to be used with dhcpcd
For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
Include files from /etc/network/interfaces.d:
auto lo
iface lo inet loopback
#auto eth0
#iface eth0 inet dhcp
iface eth0 inet auto
iface wlan0 inet auto
And also:
Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
Inform the DHCP server of our hostname for DDNS.
hostname
Use the hardware address of the interface for the Client ID.
clientid
or
Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
Some non-RFC compliant DHCP servers do not reply with this set.
In this case, comment out duid and enable clientid above.
#duid
Persist interface configuration when dhcpcd exits.
persistent
Rapid commit support.
Safe to enable by default because it requires the equivalent option set
on the server to actually work.
option rapid_commit
A list of options to request from the DHCP server.
Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
Most distributions have NTP support.
#option ntp_servers
A ServerID is required by RFC2131.
Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
Example static IP configuration:
profile static_eth0
interface eth0
static ip_address=192.168.1.101/24
static routers=192.168.1.1
static domain_name_servers=127.0.0.1
Ifconfig:
inet6 fe80::448:42ca:f2a6:a8e3 prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:a4:33:f2 txqueuelen 1000 (Ethernet)
RX packets 2071 bytes 168444 (164.4 KiB)
TX packets 27 bytes 3708 (3.6 KiB)
RX packets 8929 bytes 763858 (745.9 KiB)
TX packets 8929 bytes 763858 (745.9 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.146 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::eb8a:d19:4ffd:ddac prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:a4:33:f3 txqueuelen 1000 (Ethernet)
RX packets 12449 bytes 2419180 (2.3 MiB)
TX packets 17279 bytes 5024832 (4.7 MiB)
is obsolete (not to mention the errors). Try NORMAL Buster/Stretch settings. See How to set up networking/WiFi – Milliways Aug 02 '20 at 00:10
