I just installed the Raspian with Noobs and run perfectly the Debian raspian. But the problem start when i did it again and run the raspberry to install other OS. Q: How do i install other OS after install raspian with Noobs? I tried the some images of each OS( Ubuntu, Retro pie, OSMC,..) but had no effects
    This can't be done. Once you've completed the first NOOBS boot up nothing can change without reformatting the SDCard and starting again. It is a one-shot process. – Dougie Jul 19 '20 at 11:25
As Dougie has said you can't. (Although it may have changed in the 7 years since I was deluded enough to try it.)
NOOBS is a disaster - even the Foundation doesn't push it any more.
If you want multiple OS I suggest you try PINN instead, but most of us use one OS per SD Card.
