On Raspberrypi, the command vcgencmd measure_volts gives the voltage. Is there a way to measure the current being drawn by the Raspberry Pi at a particular time? I have a requirement of measuring energy consumption of RaspberryPi, but do not find any software tool to do so.
Asked
Active
Viewed 173 times
-1
You can't measure it without including external test equipment between your power supply and your RPi. – Dougie Jul 19 '20 at 11:27
AFAIK, there is no RPi equipped with any facility to measure its own current. I bought this device recently which meets most of my needs. There are many similar products, so review the specs to learn which one works best for you.
Seamus
- 21,900
- 3
- 33
- 70
Will we be able to read the USB C Power Meter Tester energy consumption readings through programs, say python program at run time? – SAROJ PANDA Jul 25 '20 at 21:43
@SAROJPANDA: I don't know the answer to that question. I suspect that's not supported, but I do not know that for a fact. Check with the manufacturer - or ask a question of the seller on Amazon's product page (referenced in my answer). – Seamus Jul 26 '20 at 00:10
