I would like to create a WiFi Hotspot using the Raspberry Pi. It does not have to provide a internet connection to the devices which are connected. But the raspberry Pi should still be connected to the WiFi so that it can be in the internet. I followed a tutorial to create a hotspot which works well. Unfortunately I cannot connect to the internet anymore with the raspberry pi. So is it possible that I create a "local" hotspot without internet and connect at the same time with my raspberry pi to a wifi network or is it simply impossible?
sudo nano /etc/dhcpcd.conf
interface wlan0
static ip_address=192.168.1.1/24
sudo systemctl restart dhcpcd
sudo mv /etc/dnsmasq.conf /etc/dnsmasq.conf_alt sudo nano /etc/dnsmasq.conf
interface=wlan0
DHCP-Server nicht aktiv für bestehendes Netzwerk
no-dhcp-interface=eth0
IPv4-Adressbereich und Lease-Time
dhcp-range=192.168.1.100,192.168.1.200,255.255.255.0,24h
DNS
dhcp-option=option:dns-server,192.168.1.1
dnsmasq --test -C /etc/dnsmasq.conf sudo systemctl restart dnsmasq sudo systemctl status dnsmasq sudo systemctl enable dnsmasq
sudo nano /etc/hostapd/hostapd.conf
WLAN-Router-Betrieb
Schnittstelle und Treiber
interface=wlan0 #driver=nl80211
WLAN-Konfiguration
ssid=WLANrouter channel=1 hw_mode=g ieee80211n=1 ieee80211d=1 country_code=DE wmm_enabled=1
WLAN-Verschlüsselung
auth_algs=1 wpa=2 wpa_key_mgmt=WPA-PSK rsn_pairwise=CCMP wpa_passphrase=test
sudo chmod 600 /etc/hostapd/hostapd.conf
sudo hostapd -dd /etc/hostapd/hostapd.conf
sudo nano /etc/default/hostapd
Adding
RUN_DAEMON=yes DAEMON_CONF="/etc/hostapd/hostapd.conf"
sudo systemctl unmask hostapd sudo systemctl start hostapd sudo systemctl enable hostapd
sudo nano /etc/sysctl.conf net.ipv4.ip_forward=1
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
sudo nano /etc/rc.local #Adding iptables-restore < /etc/iptables.ipv4.nat
sudo reboot
Yes, it is possible to establish an access point and connect the RasPi as client to your internet router at the same time only with one WiFi interface. It is able to use the physical interface wlan0 and create a second virtual interface ap0 on the same device. There is no need to use an additional WiFi dongle. How to do it you can look at Access point as WiFi router/repeater, optional with bridge.
Of course this example is made to connect the devices on the access point to the internet, because most people want this. But it is no problem to just cut the routing between access point and internet connection. In the tutorial in section Step 4: setup static interfaces you find to create the network file /etc/systemd/network/12-ap0.network. In this file just omit or comment the line IPMasquerade=yes. This is what the access point connects to the internet. Without it you are still able to connect from the RasPi direct to the internet using interface wlan0 but other devices on the access point cannot.
  • 42,107
  • 85
  • 197
