Setting up Raspberry Pi 4B as a routed access point
Hi guys
I want to set up my Raspberry Pi 4B as a routed access point. Many IoT-devices in the subnetwork 192.168.7.x should connect to my RasPi over an Edimax EW-788Un Wi-Fi dongle (wlan1
). The RasPi should connect itself to my home network over onboard Wi-Fi (wlan0
). Here a list of the resources I have already considered:
Simultaneously connect to a wifi network and create a wifi AP https://github.com/garyexplains/examples/blob/master/raspberry_pi_router.md https://www.raspberrypi.org/documentation/configuration/wireless/access-point-routed.md
Following those guides, I have apt-get installed
the following packages
dnsmasq
hostapd
My files are set up like so:
DHCP
/etc/dhcpcd.conf
hostname
clientid
persistent
option rapid_commit
option interface_mtu
slaac private
interface wlan1
static ip_address=192.168.7.1/24
nohook wpa_supplicant
dnsmasq
/etc/dnsmasq.conf
interface=wlan1
dhcp-range=192.168.7.100,192.168.7.120,255.255.255.0,24h
domain=wlan
address=/gw.wlan/192.168.7.1
IP-Forwarding
/etc/sysctl.conf
net.ipv4.ip_forward=1
/etc/iptables.ipv4.nat
*filter
:INPUT ACCEPT [20652:1431292]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [15820:11346033]
COMMIT
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
-A POSTROUTING -o wlan0 -j MASQUERADE
COMMIT
hostapd
/etc/hostapd/hostapd.conf
country_code=CH
interface=wlan1
driver=nl80211
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
ssid=swagsystem
wpa_passphrase=swagsystem
PROBLEM:
Upon start (sudo systemctl start hostapd
) of the hostapd service, the following error occurs:
Job for hostapd.service failed because the control process exited with error code.
See "systemctl status hostapd.service" and "journalctl -xe" for details.
Invoking systemctl status hostapd.service
yelds:
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2020-06-16 14:16:19 CEST; 924ms ago
Process: 2684 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=1/FAIL
(^^ it cut off there at the end)
iwconfig
yields:
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:"NalasEmpire"
Mode:Managed Frequency:5.5 GHz Access Point: 1C:24:CD:33:35:69
Bit Rate=200 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=70/70 Signal level=-40 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:53 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
wlan1 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Power Management:off
wlan1
(my Edimax dongle) was previously tuned in to the same network as wlan0
. The setup kind of did something to it, but idk exactly what.
Does anyone see where I went wrong or what could be the problem?
EDIT1:
I switched to using predictable network interfaces (found int
sudo rasp-config
). This switched mywlan1
to wlx08beac0a717c (idk if that changed sth.)I put in the driver
driver=nl80211
back into hostapd (idk if that changed sth.)Made it run by default using
sudo update-rc.d hostapd defaults
I used
sudo hostapd -B /etc/hostapd/hostapd.conf
to start the daemon. This turned up an Error in the config file after which it is not allow to use less than 8 characters for the WPA passphrase. Changed that and well: it works! At least to the point that a new network now appears in my choice of available wifi-networks.
A new error appeared though:
wlx08beac0a717c: interface state UNINITIALIZED->COUNTRY_UPDATE
Q1: So I know that for the onboard wifi to set the country code you can do it in raspi-config
, but how do I do it for the edimax wifi dongle?
Q2: I'm unsure whether to add an /etc/network/interfaces.d/native_wifi.cfg
file. As of the moment I don't have it, but what is its use? Do I need to set the Edimax interface to static and provide a subnetmask
? It appears in some guides, but not in all.
systemd-networkd
to do all things" ... ? new car for me ? I will have to learn more of this :) +1 – Seamus Jun 17 '20 at 19:17
