-2
I have raspberry pi 4 and when I boot it with sd card(I have tried to install with dd, rpi-imager, etcher, I have tried ubuntu, kali, raspberry) and It's allways stuck on rainbow screen. When I take same sd card and put it in raspberry pi 3 it works. When it powers on red LED lights one and green blinks 3-4 times.
I have tried:
Raspberry pi 4 stuck on rainbow screen, green LED flashes 4 times
Won't boot after removing and inserting the SD Card?
Green LED blinks 4 times, did I brick my Pi?
PI 4 sometimes doesn't boot after rebooting from command line
This happens with both screen connected and not connected. It's not power problem.
Sorry to hear about your problem. Now at this point I must ask the capacity of the SD card you're using and also the speed of it. It is really important that you use a class 10 SD card for a cheap alternative of class 4 would take ages to boot. And talking about the capacity, the official website says that you can use any capacity more than 8 GB but it's important to know that you need to format the card in a FAT32 format. FAT32 file format is default when you're using capacity between 8-32 GB. but in case of higher capacity Disk (like 64 GB or 128 GB) the default file system gets changed to either NTFS or exFAT. NTFS is a microsoft patented technology, unavailable file format on your Raspberry pi4 B, exFAT is also not supported till today. If it happens that you have a higher capacity disk (sd card). Please use a third party formatting tool called SD CARD Formatter. There you will get a prompt to select the type of File System you need to format to. Select the FAT32 format but I must tell that you won't be able to utilize full 100% of the capacity. That's all mate! Have a great day.
    If you are flashing an image you do not need to format the sd card. Read OPs other post for sd card sizes. – CoderMike Jun 09 '20 at 11:36
