pi:~ $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_buster_main_binary-armhf_Packages
E: The package lists or status file could not be parsed or opened.
Asked
Active
Viewed 3,734 times
AsianXL
- 151
- 3
- 6
2Does this answer your question? Having trouble updating - how to fix problem with MergeList? – 88weighed May 27 '20 at 09:40
There is a problem with your lists of packages which are contained in the repository. You can try to reinitialize the lists under control of the package manager. How to do that you can look at Raspberry Pi sudo apt-get update not working.
- 42,107
- 20
- 85
- 197
Try this:
sudo rm /var/lib/dpkg/status
sudo touch /var/lib/dpkg/status
If that doesn't work try this:
sudo rm /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_buster_main_binary-armhf_Packages
sudo touch /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_buster_main_binary-armhf_Packages
Unsigned_Arduino
- 247
- 2
- 12
This is terrible advice.
is the file that tracks which packages are installed on your system. If you remove it,apt
anddpkg
will entirely forget what packages you have installed, leaving you with an un-updatable system. Do not do this unless you are absolutely certain that/var/lib/dpkg/status
is the file which is broken. Rather than removing the file, make a backup:mv /var/lib/dpkg/status /var/lib/dpkg/status.maybebroken
. – Mr. DOS Jun 20 '22 at 21:23
