I have set up my Raspberry Pi (Raspberry Pi 4) as an Access Point by following this article: Setting up a Raspberry Pi as an access point - the easy way and section: Setting up an access point with a bridge.
I change the config to use WPA2 Personal (only) and tested and it works but only for some devices which is strange. For the moment 2 out of 4 devices seem to be able to connect while the others are not able.
Working devices:
  • iPad Pro (latest release)
  • Macbook Pro (latest OSX release)
Not working:
  • iPhone (latest iOS release)
  • PC with Windows 10 Pro
When changing from WPA2 to WPA1 my iPhone is able to connect but gives a security warning/information. Nevertheless using WPA1 cannot be the solution ;)
Checking the logs (syslog) I can see the device is connecting/disconnecting but no error.
my wpa_supplicant config
update_config=1
country=GB
network={ ssid="AP SSID" psk="my pass" proto=RSN key_mgmt=WPA-PSK pairwise=CCMP TKIP auth_alg=OPEN mode=2 frequency=2462 }
Any suggestion or help is appreciated on this matter.
Heath Raftery
  • 265
Pierre
  • I will have a look at it but I do not have an iPhone so I cannot test this. Is there a big difference between an iPad Pro and an iPhone? I will look for a MS Windows 10 computer for testing. Just a moment please, will come back then. – Ingo May 12 '20 at 19:18
  • I can confirm that Windows 10 does not connect with WPA2 only. I'm just looking at the debug output of wpa_supplicant. – Ingo May 13 '20 at 17:42
I can confirm that MS Windows 10 has a problem to connect to an access point established by wpa_supplicant (using mode=2) and only accepting WPA2 (RSN) encryption. I haven't seen this before in my tutorial you have used, because I still use WPA encryption as fallback. And that works.
About IPhone I cannot say something because I don't have one.
I have looked at the debug output of wpa_supplicant and see that MS Windows 10 just does not response to the WPA 4-Way Handshake initiated by wpa_supplicant. Because MS Windows 10 can connect to my home WiFi internet hotspot using WPA2, I suspect that wpa_supplicant has a problem here. You may consider to file a bug report to the wpa_supplicant development.
You can also try to use hostapd instead of wpa_supplicant.
  • 42,107
  • 85
  • 197
This appears to be a broader insidious issue with wpa_supplicant (on Debian only?), and not limited to the Pi. After many, many hours of following misleading symptoms, I can confirm that with:
  • wpa_supplicant 2.8 on Debian Buster with default config plus mode=2, ssid and psk set, and every permutation of pairwise, group, auth_alg, frequency that could reasonable be tested;
  • a wl81xxMOD WiFi module and the mainline wl81xx/wlcore kernel drivers;
  • dnsmasq providing DHCP.
The client experience is either:
  • connect without issue:
    • Early 2013 MacBook Pro running macos 10.14.6 (Mojave)
    • iPhone SE running iOS 13.6
    • Old Toshiba laptop running Windows 7
  • report "unable to connect" or periodically cycle from connected to disconnected every 2 to 6 seconds:
    • Late model desktop PC running Windows 10.
    • Ancient ASUS laptop running Windows 10.
    • 2020 iMac running macos 10.15.6 (Catalina)
Changing to either Open (key_mgmt=NONE) or disabling WPA2 (proto=wpa) causes all clients to connect without issue.
My theory, uncomfortable as it is, is:
wpa_supplicant, by default, advertises WPA and WPA2 but does not provide a WPA2 Authenticator. Old clients just use WPA and never notice. Newer clients (including Mojave on a 2020 iMac) try WPA2, which does not complete so they drop the connection and mystery abounds.
The resolution appears to be:
wpa_supplicant must be configured with proto=wpa to disable WPA2, or wpa_supplicant must be replaced with something that provides an WPA2 Authenticator like hostapd.
This is despite the wpa_supplicant Change Log stating that way back in 2009-11-21 (v0.7.0), parts of hostapd functionality were linked in so that "AP mode functionality can be used for WPA2-Personal networks". On the other hand, the author's web page does state that wpa_supplicant implements "a WPA Authenticator" while hostapd includes a "IEEE 802.1X/WPA/WPA2 Authenticator".
I still do not understand why for those clients that take 6 seconds before disassociation, the WiFi connection appears to be completely useable. If it really is an authentication issue, that seems like a glaring security hole.
Full log of my investigation that led to this conclusion appears here.
Heath Raftery
  • 265
