There's a bunch of controls you can use in /boot/config.txt
act_led_trigger Choose which activity the LED tracks.
Use "heartbeat" for a nice load indicator.
(default "mmc")
act_led_activelow Set to "on" to invert the sense of the LED
(default "off")
N.B. For Pi 3B, 3B+, 3A+ and 4B, use the act-led
overlay.
act_led_gpio Set which GPIO to use for the activity LED
(in case you want to connect it to an external
device)
(default "16" on a non-Plus board, "47" on a
Plus or Pi 2)
overlay.
pwr_led_trigger
pwr_led_activelow
pwr_led_gpio
As for act_led_*, but using the PWR LED.
Not available on Model A/B boards.
And
Info: Pi 3B, 3B+, 3A+ and 4B use a GPIO expander to drive the LEDs which can
only be accessed from the VPU. There is a special driver for this with a
separate DT node, which has the unfortunate consequence of breaking the
act_led_gpio and act_led_activelow dtparams.
This overlay changes the GPIO controller back to the standard one and
restores the dtparams.
Load: dtoverlay=act-led,<param>=<val>
Params: activelow Set to "on" to invert the sense of the LED
(default "off")
device)
REQUIRED
For example my Zero has
dtparam=act_led_activelow=on
so that the LED isn't a power LED, but works like a activity LED (on other RPis)
Take a look at /boot/overlays/README
for details.
You probably want
dtparam=pwr_led_activelow=on
to turn your RED LED off. I don't have a RPi4B, so I can't test that and confirm it does what you want. This does the same thing as @Dirk's answer but without needing a script run at boot time.
none
anddefault-on
) documented? – Seamus Jun 11 '21 at 05:59@reboot echo none > /sys/class/leds/led1/trigger
in root's crontab. – Greg Chabala Mar 12 '22 at 20:24
