Just flashed a card with Raspbian Buster Lite on a Raspberry Pi 2, and ssh'd into it using an ethernet cable. raspi-config
/wpa_cli
can't communicate with wpa_supplicant
(there's no /var/run/wpa_supplicant
control interface).
At the end of the post I explain a workaround, but it's not permanent.
Here's some debugging information,
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
pi@raspberrypi:~ $ ps aux | grep wpa
root 289 0.0 0.4 10740 3976 ? Ss may02 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
pi 915 0.0 0.0 7356 496 pts/0 S+ 00:00 0:00 grep --color=auto wpa
pi@raspberrypi:~ $ sudo systemctl status wpa_supplicant.service
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-05-04 02:04:51 -03; 2min 50s ago
Main PID: 602 (wpa_supplicant)
Tasks: 1 (limit: 2200)
Memory: 496.0K
CGroup: /system.slice/wpa_supplicant.service
└─602 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
may 04 02:04:51 raspberrypi systemd[1]: Starting WPA supplicant...
may 04 02:04:51 raspberrypi systemd[1]: Started WPA supplicant.
may 04 02:04:51 raspberrypi wpa_supplicant[602]: Successfully initialized wpa_supplicant
pi@raspberrypi:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
country=US
network={
ssid="****"
psk="****"
As you can see, I've only edited the config with network's ssid/psk after failing at raspi-config
Here's my usb wifi adapter / driver,
pi@raspberrypi:~ $ sudo lsusb -v
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0bda Realtek Semiconductor Corp.
idProduct 0x8179 RTL8188EUS 802.11n Wireless Network Adapter
bcdDevice 0.00
iManufacturer 1 Realtek
iProduct 2 802.11n NIC
iSerial 3 00E04C0001
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0027
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0002
(Bus Powered)
Remote Wakeup Enabled
pi@raspberrypi:~ $ ip addr show wlan0
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 18:a6:f7:1d:36:90 brd ff:ff:ff:ff:ff:ff
pi@raspberrypi:~ $ cat /var/log/syslog
May 3 00:04:04 raspberrypi kernel: [ 8.225728] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
May 3 00:04:04 raspberrypi kernel: [ 8.324223] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
May 3 00:04:04 raspberrypi kernel: [ 8.362213] usbcore: registered new interface driver r8188eu
May 3 00:04:04 raspberrypi kernel: [ 10.939312] random: crng init done
May 3 00:04:04 raspberrypi kernel: [ 10.939336] random: 7 urandom warning(s) missed due to ratelimiting
May 3 00:04:04 raspberrypi kernel: [ 11.394678] 8021q: 802.1Q VLAN Support v1.8
May 3 00:04:04 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
May 3 00:04:04 raspberrypi systemd[1]: Started System Logging Service.
May 3 00:04:05 raspberrypi avahi-daemon[288]: Successfully called chroot().
May 3 00:04:05 raspberrypi avahi-daemon[288]: Successfully dropped remaining capabilities.
May 3 00:04:05 raspberrypi avahi-daemon[288]: No service file found in /etc/avahi/services.
May 3 00:04:05 raspberrypi avahi-daemon[288]: Network interface enumeration completed.
May 3 00:04:05 raspberrypi avahi-daemon[288]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 2935413426.
May 3 00:04:05 raspberrypi wpa_supplicant[307]: Successfully initialized wpa_supplicant
May 3 00:04:05 raspberrypi systemd[1]: Started Login Service.
May 3 00:04:05 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
May 3 00:04:05 raspberrypi systemd[1]: Started WPA supplicant.
May 3 00:04:05 raspberrypi raspi-config[313]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
May 3 00:04:05 raspberrypi raspi-config[313]: No. Switching to ondemand scaling governor.
May 3 00:04:05 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
May 3 00:04:05 raspberrypi kernel: [ 11.661234] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
May 3 00:04:05 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
May 3 00:04:05 raspberrypi dhcpcd[306]: eth0: waiting for carrier
May 3 00:04:05 raspberrypi kernel: [ 11.679881] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
May 3 00:04:05 raspberrypi dhcpcd[306]: wlan0: waiting for carrier
May 3 00:04:05 raspberrypi dhcpcd[306]: eth0: carrier acquired
May 3 00:04:05 raspberrypi kernel: [ 12.338131] MAC Address = 18:a6:f7:1d:36:90
May 3 00:04:05 raspberrypi kernel: [ 12.341657] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
After reading some posts, people seems to have issues with the driver, so tried with wext
pi@raspberrypi:~ $ sudo pkill wpa_supplicant
pi@raspberrypi:~ $ sudo wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf -D wext
rfkill: Cannot get wiphy information
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
root 496 0.2 0.2 10996 2760 ? Ss 01:58 0:00 wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf -D wext
That worked, and wlan0
went up, but I'm not sure how to keep it permanent for reboot, because it's not clear who is responsable for starting wpa_supplicant, dhcpcd
hooks (10-wpa_supplicant.conf
)? systemd
's wpa_supplicant dbus service?
According to ps aux
output, it's using the DBus service, and tried adding -Dwext
parameter on ExecStart
and rebooted but didn't work. It's like the default DBus version doesn't work. Is it expecting NetworkManager to be installed or something?
root 321 0.2 0.4 10740 3972 ? Ss 01:56 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant -Dwext
When running wpa_supplicant using the default nl80211 I get this output,
pi@raspberrypi:~ $ sudo /sbin/wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant.conf -i wlan0
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: Failed to initialize driver interface
raspi-config
, right? I can't even do that because it fails communicating with wpa_supplicant control interface (there's no /var/run/wpa_supplicant created at boot). I had already set country code and rebooted and it doesn't matter, at least for my interface.dhcpcd
doesn't seem to start wlan0, whereas starting wpa_supplicant settingwext
driver manually does work. – soundblaster May 04 '20 at 13:53ls /sys/class/net
will show if there is a wireless interface - if not fiddling with other files is futile. – Milliways May 05 '20 at 00:45wpa_supplicant.conf
file and made no other changes. – Daniele Procida May 08 '21 at 09:16
