Heyo, I use my raspberry pi zero as an rgb strip controller behind my desk, I have a simple http/php server running on it so I can change the color from my web browser, it is powered by a phone charger and also connected directly to my pc via the second usb port, and that's how it gets it's internet. Thing is, every morning I have to go into putty, log in with the default pi/raspberry username and password and type in sudo pigpiod so I can start controlling the strip online... This takes about a minute and I thought I'd just shorten it 2x by removing the login bs, tried finding any results on how and didn't have great luck, but I did find this post: How can I deactivate the login password on my Raspberry Pi? . I followed it's instructions and made sure to set those settings to no, restarted my pi and putty. And now when I try to log in putty still asks for a username, and if I type anything in at all it brings me this message: "disconnected: no supported authentication methods available (server sent: publickey)" and I can't get into my pi through putty... the equipment I used to set it up (keyboard/mouse/usb hub/ 5 adapters for all the connections) is who knows where in the attic so I'll just leave it be and live without rgb if there is no simple solution within putty >_>
Asked
Active
Viewed 263 times
Try writing in paragraphs – Milliways Apr 27 '20 at 22:21
There is a solution to start automatically pigpio :
wget https://raw.githubusercontent.com/joan2937/pigpio/master/util/pigpiod.service
sudo cp pigpiod.service /etc/systemd/system
sudo systemctl enable pigpiod.service
sudo systemctl start pigpiod.service
So when you start your raspberry pi, pigpiod start automatically and so you don't have to connect to your raspberry pi with putty.
Hope this will help you :).
Buisson
- 181
- 2
- 9
Isn't the service already installed on Raspbian and just needs enabling? Option Remote GPIO in
raspi-config– Dirk Apr 27 '20 at 14:41 -
Here is the link where I found that solution : https://github.com/guymcswain/pigpio-client/wiki/Install-and-configure-pigpiod – Buisson Apr 27 '20 at 15:27
