Cortex A72, the arm core used in Raspberry Pi 4 is not on the support list of libpfm.
It seems the PMU of Cortex A72 is similar to Cortex A57, so you can add support for Cortex A72 by duplicating the code for Cortex A57.
Here is a patch I made on papi 6.0.0.1 release, so after clone the repo, git checkout
to tag papi-6-0-0-1-t
, then git am
to apply this patch.
From d330ba03c1f4ae2c819c48095ffc9c0fea1e0ef2 Mon Sep 17 00:00:00 2001
Date: Thu, 14 May 2020 06:52:16 +0000
Subject: [PATCH] Add support for Cortex A72
src/libpfm4/include/perfmon/pfmlib.h | 1 +
src/libpfm4/lib/Makefile | 4 +-
.../lib/events/arm_cortex_a72_events.h | 440 ++++++++++++++++++
src/libpfm4/lib/pfmlib_arm_armv8.c | 42 ++
src/libpfm4/lib/pfmlib_common.c | 2 +
src/libpfm4/lib/pfmlib_priv.h | 1 +
src/papi_events.csv | 1 +
7 files changed, 490 insertions(+), 1 deletion(-)
create mode 100644 src/libpfm4/lib/events/arm_cortex_a72_events.h
diff --git a/src/libpfm4/include/perfmon/pfmlib.h b/src/libpfm4/include/perfmon/pfmlib.h
index 35d2e5795..d2b70daa2 100644
--- a/src/libpfm4/include/perfmon/pfmlib.h
+++ b/src/libpfm4/include/perfmon/pfmlib.h
@@ -239,6 +239,7 @@ typedef enum {
PFM_PMU_S390X_CPUM_SF, /* s390x: CPU-M sampling facility */
- PFM_PMU_ARM_CORTEX_A72, /* ARM Cortex A72 (ARMv8) /
PFM_PMU_ARM_CORTEX_A57, / ARM Cortex A57 (ARMv8) /
PFM_PMU_ARM_CORTEX_A53, / ARM Cortex A53 (ARMv8) */
diff --git a/src/libpfm4/lib/Makefile b/src/libpfm4/lib/Makefile
index 055696761..6e4d33233 100644
--- a/src/libpfm4/lib/Makefile
+++ b/src/libpfm4/lib/Makefile
@@ -359,12 +359,14 @@ INC_ARM=pfmlib_arm_priv.h
events/arm_cortex_a8_events.h
events/arm_cortex_a9_events.h
events/arm_cortex_a15_events.h \
- events/arm_cortex_a72_events.h
events/arm_cortex_a57_events.h
events/arm_cortex_a53_events.h
events/arm_cavium_tx2_events.h
events/arm_marvell_tx2_unc_events.h
-INC_ARM64=events/arm_cortex_a57_events.h
+INC_ARM64=events/arm_cortex_a72_events.h \
- events/arm_cortex_a57_events.h
diff --git a/src/libpfm4/lib/events/arm_cortex_a72_events.h b/src/libpfm4/lib/events/arm_cortex_a72_events.h
new file mode 100644
index 000000000..f695ac4a3
--- /dev/null
+++ b/src/libpfm4/lib/events/arm_cortex_a72_events.h
@@ -0,0 +1,440 @@
- Copyright (c) 2020 University of Texas at Austin. All rights reserved
- Contributed by Qinzhe Wu <qw2699@utexas.edu>
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the "Software"), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
- of the Software, and to permit persons to whom the Software is furnished to do so,
- subject to the following conditions:
- The above copyright notice and this permission notice shall be included in all
- copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
- INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
- PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
- HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
- CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
- OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
- based on Table 11-24 from the "Cortex A72 Technical Reference Manual"
+static const arm_entry_t arm_cortex_a72_pe[]={
- {.name = "SW_INCR",
- .modmsk = ARMV8_ATTRS,
- .code = 0x00,
- .desc = "Instruction architecturally executed (condition check pass) Software increment"
- {.name = "L1I_CACHE_REFILL",
- .code = 0x01,
- .desc = "Level 1 instruction cache refill"
- {.name = "L1I_TLB_REFILL",
- .code = 0x02,
- .desc = "Level 1 instruction TLB refill"
- {.name = "L1D_CACHE_REFILL",
- .code = 0x03,
- .desc = "Level 1 data cache refill"
- {.name = "L1D_CACHE_ACCESS",
- .code = 0x04,
- .desc = "Level 1 data cache access"
- {.name = "L1D_TLB_REFILL",
- .code = 0x05,
- .desc = "Level 1 data TLB refill"
- {.name = "INST_RETIRED",
- .code = 0x08,
- .desc = "Instruction architecturally executed"
- {.name = "EXCEPTION_TAKEN",
- .code = 0x09,
- .desc = "Exception taken"
- {.name = "EXCEPTION_RETURN",
- .code = 0x0a,
- .desc = "Instruction architecturally executed (condition check pass) Exception return"
- {.name = "CID_WRITE_RETIRED",
- .code = 0x0b,
- .desc = "Instruction architecturally executed (condition check pass) Write to CONTEXTIDR"
- {.name = "BRANCH_MISPRED",
- .code = 0x10,
- .desc = "Mispredicted or not predicted branch speculatively executed"
- {.name = "CPU_CYCLES",
- .code = 0x11,
- .desc = "Cycles"
- {.name = "BRANCH_PRED",
- .code = 0x12,
- .desc = "Predictable branch speculatively executed"
- {.name = "DATA_MEM_ACCESS",
- .code = 0x13,
- .desc = "Data memory access"
- {.name = "L1I_CACHE_ACCESS",
- .code = 0x14,
- .desc = "Level 1 instruction cache access"
- {.name = "L1D_CACHE_WB",
- .code = 0x15,
- .desc = "Level 1 data cache WriteBack"
- {.name = "L2D_CACHE_ACCESS",
- .code = 0x16,
- .desc = "Level 2 data cache access"
- {.name = "L2D_CACHE_REFILL",
- .code = 0x17,
- .desc = "Level 2 data cache refill"
- {.name = "L2D_CACHE_WB",
- .code = 0x18,
- .desc = "Level 2 data cache WriteBack"
- {.name = "BUS_ACCESS",
- .code = 0x19,
- .desc = "Bus access"
- {.name = "LOCAL_MEMORY_ERROR",
- .code = 0x1a,
- .desc = "Local memory error"
- {.name = "INST_SPEC_EXEC",
- .code = 0x1b,
- .desc = "Instruction speculatively executed"
- {.name = "TTBR_WRITE_RETIRED",
- .code = 0x1c,
- .desc = "Instruction architecturally executed (condition check pass) Write to translation table base"
- {.name = "BUS_CYCLES",
- .code = 0x1d,
- .desc = "Bus cycle"
- {.name = "L1D_READ_ACCESS",
- .code = 0x40,
- .desc = "Level 1 data cache read access"
- {.name = "L1D_WRITE_ACCESS",
- .code = 0x41,
- .desc = "Level 1 data cache write access"
- {.name = "L1D_READ_REFILL",
- .code = 0x42,
- .desc = "Level 1 data cache read refill"
- {.name = "L1D_WRITE_REFILL",
- .code = 0x43,
- .desc = "Level 1 data cache write refill"
- {.name = "L1D_WB_VICTIM",
- .code = 0x46,
- .desc = "Level 1 data cache writeback victim"
- {.name = "L1D_WB_CLEAN_COHERENCY",
- .code = 0x47,
- .desc = "Level 1 data cache writeback cleaning and coherency"
- {.name = "L1D_INVALIDATE",
- .code = 0x48,
- .desc = "Level 1 data cache invalidate"
- {.name = "L1D_TLB_READ_REFILL",
- .code = 0x4c,
- .desc = "Level 1 data TLB read refill"
- {.name = "L1D_TLB_WRITE_REFILL",
- .code = 0x4d,
- .desc = "Level 1 data TLB write refill"
- {.name = "L2D_READ_ACCESS",
- .code = 0x50,
- .desc = "Level 2 data cache read access"
- {.name = "L2D_WRITE_ACCESS",
- .code = 0x51,
- .desc = "Level 2 data cache write access"
- {.name = "L2D_READ_REFILL",
- .code = 0x52,
- .desc = "Level 2 data cache read refill"
- {.name = "L2D_WRITE_REFILL",
- .code = 0x53,
- .desc = "Level 2 data cache write refill"
- {.name = "L2D_WB_VICTIM",
- .code = 0x56,
- .desc = "Level 2 data cache writeback victim"
- {.name = "L2D_WB_CLEAN_COHERENCY",
- .code = 0x57,
- .desc = "Level 2 data cache writeback cleaning and coherency"
- {.name = "L2D_INVALIDATE",
- .code = 0x58,
- .desc = "Level 2 data cache invalidate"
- {.name = "BUS_READ_ACCESS",
- .code = 0x60,
- .desc = "Bus read access"
- {.name = "BUS_WRITE_ACCESS",
- .code = 0x61,
- .desc = "Bus write access"
- {.name = "BUS_NORMAL_ACCESS",
- .code = 0x62,
- .desc = "Bus normal access"
- {.name = "BUS_NOT_NORMAL_ACCESS",
- .code = 0x63,
- .desc = "Bus not normal access"
- {.name = "BUS_NORMAL_ACCESS_2",
- .code = 0x64,
- {.name = "BUS_PERIPH_ACCESS",
- .code = 0x65,
- .desc = "Bus peripheral access"
- {.name = "DATA_MEM_READ_ACCESS",
- .code = 0x66,
- .desc = "Data memory read access"
- {.name = "DATA_MEM_WRITE_ACCESS",
- .code = 0x67,
- .desc = "Data memory write access"
- {.name = "UNALIGNED_READ_ACCESS",
- .code = 0x68,
- .desc = "Unaligned read access"
- {.name = "UNALIGNED_WRITE_ACCESS",
- .code = 0x69,
- {.name = "UNALIGNED_ACCESS",
- .code = 0x6a,
- .desc = "Unaligned access"
- {.name = "INST_SPEC_EXEC_LDREX",
- .code = 0x6c,
- .desc = "LDREX exclusive instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_STREX_PASS",
- .code = 0x6d,
- .desc = "STREX pass exclusive instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_STREX_FAIL",
- .code = 0x6e,
- .desc = "STREX fail exclusive instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_LOAD",
- .code = 0x70,
- .desc = "Load instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_STORE",
- .code = 0x71,
- .desc = "Store instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_LOAD_STORE",
- .code = 0x72,
- .desc = "Load or store instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_INTEGER_INST",
- .code = 0x73,
- .desc = "Integer data processing instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_SIMD",
- .code = 0x74,
- .desc = "Advanced SIMD instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_VFP",
- .code = 0x75,
- .desc = "VFP instruction speculatively executed"
- {.name = "INST_SPEC_EXEC_SOFT_PC",
- .code = 0x76,
- .desc = "Software of the PC instruction speculatively executed"
- {.name = "BRANCH_SPEC_EXEC_IMM_BRANCH",
- .code = 0x78,
- .desc = "Immediate branch speculatively executed"
- {.name = "BRANCH_SPEC_EXEC_RET",
- .code = 0x79,
- .desc = "Return branch speculatively executed"
- {.name = "BRANCH_SPEC_EXEC_IND",
- .code = 0x7a,
- .desc = "Indirect branch speculatively executed"
- {.name = "BARRIER_SPEC_EXEC_ISB",
- .code = 0x7c,
- .desc = "ISB barrier speculatively executed"
- {.name = "BARRIER_SPEC_EXEC_DSB",
- .code = 0x7d,
- .desc = "DSB barrier speculatively executed"
- {.name = "BARRIER_SPEC_EXEC_DMB",
- .code = 0x7e,
- .desc = "DMB barrier speculatively executed"
- {.name = "EXCEPTION_UNDEF",
- .code = 0x81,
- .desc = "Exception taken, other synchronous"
- {.name = "EXCEPTION_SVC",
- .code = 0x82,
- .desc = "Exception taken, supervisor call"
- {.name = "EXCEPTION_PABORT",
- .code = 0x83,
- .desc = "Exception taken, instruction abort"
- {.name = "EXCEPTION_DABORT",
- .code = 0x84,
- .desc = "Exception taken, data abort or SError"
- {.name = "EXCEPTION_IRQ",
- .code = 0x86,
- .desc = "Exception taken, irq"
- {.name = "EXCEPTION_FIQ",
- .code = 0x87,
- {.name = "EXCEPTION_SMC",
- .code = 0x88,
- .desc = "Exception taken, secure monitor call"
- {.name = "EXCEPTION_HVC",
- .code = 0x8a,
- .desc = "Exception taken, hypervisor call"
- {.name = "EXCEPTION_TRAP_PABORT",
- .code = 0x8b,
- .desc = "Exception taken, instruction abort not taken locally"
- {.name = "EXCEPTION_TRAP_DABORT",
- .code = 0x8c,
- .desc = "Exception taken, data abort or SError not taken locally"
- {.name = "EXCEPTION_TRAP_OTHER",
- .code = 0x8d,
- .desc = "Exception taken, other traps not taken locally"
- {.name = "EXCEPTION_TRAP_IRQ",
- .code = 0x8e,
- .desc = "Exception taken, irq not taken locally"
- {.name = "EXCEPTION_TRAP_FIQ",
- .code = 0x8f,
- .desc = "Exception taken, fiq not taken locally"
- {.name = "RC_LD_SPEC",
- .code = 0x90,
- .desc = "Release consistency instruction speculatively executed (load-acquire)",
- {.name = "RC_ST_SPEC",
- .code = 0x91,
- .desc = "Release consistency instruction speculatively executed (store-release)",
- /* END Cortex A72 specific events */
diff --git a/src/libpfm4/lib/pfmlib_arm_armv8.c b/src/libpfm4/lib/pfmlib_arm_armv8.c
index a252951cf..affc619be 100644
--- a/src/libpfm4/lib/pfmlib_arm_armv8.c
+++ b/src/libpfm4/lib/pfmlib_arm_armv8.c
@@ -30,12 +30,29 @@
#include "pfmlib_priv.h" /* library private */
#include "pfmlib_arm_priv.h"
+#include "events/arm_cortex_a72_events.h" /* A72 event tables /
#include "events/arm_cortex_a57_events.h" / A57 event tables /
#include "events/arm_cortex_a53_events.h" / A53 event tables /
#include "events/arm_xgene_events.h" / Applied Micro X-Gene tables /
#include "events/arm_cavium_tx2_events.h" / Marvell ThunderX2 tables /
#include "events/arm_marvell_tx2_unc_events.h" / Marvell ThunderX2 PMU tables */
+static int
+pfm_arm_detect_cortex_a72(void *this)
static int
pfm_arm_detect_cortex_a57(void this)
@@ -104,6 +121,31 @@ pfm_arm_detect_thunderx2(void this)
return PFM_ERR_NOTSUPP;
+/* ARM Cortex A72 support */
+pfmlib_pmu_t arm_cortex_a72_support={
- .desc = "ARM Cortex A72",
- .name = "arm_ac72",
- .pmu = PFM_PMU_ARM_CORTEX_A72,
- .pme_count = LIBPFM_ARRAY_SIZE(arm_cortex_a72_pe),
- .type = PFM_PMU_TYPE_CORE,
- .pe = arm_cortex_a72_pe,
- .pmu_detect = pfm_arm_detect_cortex_a72,
- .max_encoding = 1,
- .num_cntrs = 6,
- .get_event_encoding[PFM_OS_NONE] = pfm_arm_get_encoding,
- PFMLIB_ENCODE_PERF(pfm_arm_get_perf_encoding),
- .get_event_first = pfm_arm_get_event_first,
- .get_event_next = pfm_arm_get_event_next,
- .event_is_valid = pfm_arm_event_is_valid,
- .validate_table = pfm_arm_validate_table,
- .get_event_info = pfm_arm_get_event_info,
- .get_event_attr_info = pfm_arm_get_event_attr_info,
- PFMLIB_VALID_PERF_PATTRS(pfm_arm_perf_validate_pattrs),
- .get_event_nattrs = pfm_arm_get_event_nattrs,
/* ARM Cortex A57 support /
pfmlib_pmu_t arm_cortex_a57_support={
.desc = "ARM Cortex A57",
diff --git a/src/libpfm4/lib/pfmlib_common.c b/src/libpfm4/lib/pfmlib_common.c
index 43a333432..6c71df4b5 100644
--- a/src/libpfm4/lib/pfmlib_common.c
+++ b/src/libpfm4/lib/pfmlib_common.c
@@ -482,6 +482,7 @@ static pfmlib_pmu_t pfmlib_pmus[]=
&arm_cortex_a15_support,
&arm_1176_support,
&arm_qcom_krait_support,
- &arm_cortex_a72_support,
&arm_cortex_a57_support,
&arm_cortex_a53_support,
&arm_xgene_support,
@@ -494,6 +495,7 @@ static pfmlib_pmu_t *pfmlib_pmus[]=
&arm_thunderx2_ccpi1_support,
#endif
#ifdef CONFIG_PFMLIB_ARCH_ARM64
&arm_xgene_support,
diff --git a/src/libpfm4/lib/pfmlib_priv.h b/src/libpfm4/lib/pfmlib_priv.h
index 796aa74dd..c813fd5e0 100644
--- a/src/libpfm4/lib/pfmlib_priv.h
+++ b/src/libpfm4/lib/pfmlib_priv.h
@@ -645,6 +645,7 @@ extern pfmlib_pmu_t arm_cortex_a9_support;
extern pfmlib_pmu_t arm_cortex_a15_support;
extern pfmlib_pmu_t arm_1176_support;
extern pfmlib_pmu_t arm_qcom_krait_support;
+extern pfmlib_pmu_t arm_cortex_a72_support;
extern pfmlib_pmu_t arm_cortex_a57_support;
extern pfmlib_pmu_t arm_cortex_a53_support;
extern pfmlib_pmu_t arm_xgene_support;
diff --git a/src/papi_events.csv b/src/papi_events.csv
index 8e96adfbd..a58c53a18 100644
--- a/src/papi_events.csv
+++ b/src/papi_events.csv
@@ -1772,6 +1772,7 @@ PRESET,PAPI_L1_ICM,NOT_DERIVED,IFETCH_MISS
CPU,arm_ac15
CPU,arm_ac57
+CPU,arm_ac72
PRESET,PAPI_TOT_INS,NOT_DERIVED,INST_RETIRED
PRESET,PAPI_TOT_IIS,NOT_DERIVED,INST_SPEC_EXEC
2.17.1
(Note: copy/paste from the code block above seems to replace all s with spaces, so please use the link to download the patch file if the git am
command fails).
I have tested with the example code on my Raspberry Pi 4 board (4.19 kernel), so it should work.
BTW, make sure /proc/sys/kernel/perf_event_paranoid
has value -1, and perf
works fine on my board also.
