I have custom buildroot image built for Raspberry Pi Zero W. My primary goal is to be able to activate on-board blueetoth, however I seem to have immense problems achieving it. My main problem is that no matter what I do my system cannot detect any bluetooth adapters.
My buildroot .config: https://github.com/KarolPWr/Bluetooth-buildroot-rpi/blob/master/.config
Releveant part of config.txt:
# fixes rpi3 ttyAMA0 serial console
dtoverlay=pi3-miniuart-bt
# enable rpi3 ttyS0 serial console
enable_uart=1
cmdline.txt:
root=/dev/mmcblk0p2 rootwait console=tty1 console=ttyAMA0,115200
What I do after boot finishes:
modprobe hci_uart
rfcomm
bluetoothd
All starts without errors. Then when I type bt-device -l
, no adapter is shown.
When executing command hciattach /dev/ttyS0 any 921600 noflow -
I get informed of several bluetooth timeouts and then I only get:
# hciconfig -a
hci0: Type: BR/EDR Bus: UART
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN
RX bytes:0 acl:0 sco:0 events:0 errors:0
TX bytes:12 acl:0 sco:0 commands:3 errors:0
I also tried hciattach /dev/ttyS0 bcm43xx 921600 noflow -
But this fails with Unknown device type or id
I've already spent many hours researching various resources, but I still feel very lost.
As a sidenote, I'd like to preserve serial console on GPIO pins, since its very useful for debugging. For now I have no idea how to make this configuration work.
dtoverlay -h pi3-miniuart-bt
that said It is also necessary to edit /lib/systemd/system/hciuart.service and replace ttyAMA0 with ttyS0 Not sure if either of these are a fix for you with the custom build. – Apr 19 '20 at 19:01power on
command? There was a quirk back in Jessie where this was required... – Jun 21 '20 at 16:02
