I am trying to create a Tor Router with a Raspberry Pi 4, the newest raspbian version, the inbuild Wlan0-Card for the Access-Point and a external Edimax Usb Wlan1-Card to get a internet connection.
I am successfull in creating the Access-Point i can connect to it with my "Galaxy S9" and i can surf in the Internet with my real ip Address.
But i can not get the tor part to work because, as soon as i start tor and add the iptables for tor i have no internet connection anymore on my "Galaxy S9".
Here are my steps which i did:
CREATING THE ACCESS-POINT:
separated wpa_supplicant configurations by interface
$ cd /etc/wpa_supplicant $ sudo cp wpa_supplicant.conf wpa_supplicant-wlan0.conf $ sudo cp wpa_supplicant.conf wpa_supplicant-wlan1.conf
added my wifi ssid and pass
network={ ssid="MYSSID" psk="MYPlainTextPassword" }
installed hostapd and dnsmasq
$ sudo apt-get install hostapd dnsmasq
edited "/etc/dhcpcd.conf"
interface wlan0 static ip_address=192.168.179.1/24
edited "/etc/dnsmasq.conf"
interface=wlan0 no-dhcp-interface=wlan1 dhcp-range=192.168.179.10,192.168.179.150,24h dhcp-option=option:dns-server,8.8.8.8
edited "/etc/hostapd/hostapd.conf"
interface=wlan0 ssid=TorWifi channel=9 auth_algs=1 wpa=2 wpa_passphrase=TorWifi123 wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP CCMP wpa_group_rekey=86400
edited "/etc/default/hostapd"
DAEMON_CONF="/etc/hostapd/hostapd.conf"
edited "/etc/sysctl.conf"
net.ipv4.ip_forward=1
added iptables to test the Access-Point
$ sudo iptables -t nat -A POSTROUTING -o wlan1 -j MASQUERADE $ sudo iptables -A FORWARD -i wlan1 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT $ sudo iptables -A FORWARD -i wlan0 -o wlan1 -j ACCEPT
Access-Point Successfully created and working
$ sudo systemctl start dnsmasq $ sudo systemctl start hostapd
TOR CONFIGURATION:
installed tor
$ sudo apt-get install tor
edited "/etc/tor/torrc"
# Transparent proxy port
TransPort 9040
TransListenAddress 192.168.179.1
# Explicit SOCKS port for applications.
SocksPort 9050
# Have Tor run in the background
RunAsDaemon 1
# Only ever run as a client. Do not run as a relay or an exit.
ClientOnly
# Ensure resolution of .onion and .exit domains happen through Tor.
AutomapHostsSuffixes .onion,.exit
AutomapHostsOnResolve 1
VirtualAddrNetwork 10.192.0.0/10
# Serve DNS responses
DNSPort 53
DNSListenAddress 192.168.179.1
added iptables
$ sudo iptables -F $ sudo iptables -t nat -F $ sudo iptables -t nat -A PREROUTING -i wlan0 -p tcp --dport 22 -j REDIRECT --to-ports 22 $ sudo iptables -t nat -A PREROUTING -i wlan0 -p udp --dport 53 -j REDIRECT --to-ports 53 $ sudo iptables -t nat -A PREROUTING -i wlan0 -p tcp --syn -j REDIRECT --to-ports 9040
0 Answers0
