I have a problem with wifi access point on Raspberry 3B+.
/etc/hostapd/hostapd.conf:
interface=wlan0
driver=nl80211
ssid=Rpi_ap
hw_mode=g
channel=7
ieee80211n=1
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=1234567890
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
logger_syslog=-1
ht_capab=[HT40][SHORT-GI-20][DSSS_CCK-40]
/etc/dnsmasq.conf
interface=wlan0
dhcp-range=192.168.5.100,192.168.5.200,255.255.255.0,24h
pi@raspberrypi:~ $ ifconfig wlan0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.5.1 netmask 255.255.255.0 broadcast 192.168.5.255
inet6 fe80::ba27:ebff:fe5c:49c7 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:5c:49:c7 txqueuelen 1000 (Ethernet)
RX packets 19442 bytes 1854583 (1.7 MiB)
TX packets 1101 bytes 146273 (142.8 KiB)
i do
sudo ifconfig wlan0 192.168.5.1 netmask 255.255.255.0 broadcast 192.168.5.255
sudo systemctl start dnsmasq.service
sudo hostapd -d /etc/hostapd/hostapd.conf
output here https://pastebin.com/EAxFFeA4
As result i have no access point. What i do wrong? What could be the reason?
UPD:
I found a mistake in cat /etc/default/hostapd (thanks @M. Rostami) and fixed it. But acceess point didn't appear.
/etc/default/hostap:
DAEMON_CONF="/etc/hostapd/hostapd.conf"
pi@raspberrypi:~ $ sudo service hostapd status
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
Loaded: loaded (/lib/systemd/system/hostapd.service; disabled; vendor preset: enabled)
Active: active (running) since Wed 2020-03-11 14:15:29 MSK; 2min 21s ago
Process: 1309 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=0/SUCCESS)
Main PID: 1310 (hostapd)
Tasks: 1 (limit: 2200)
Memory: 1.8M
CGroup: /system.slice/hostapd.service
└─1310 /usr/sbin/hostapd -B -P /run/hostapd.pid -B
мар 11 14:15:29 raspberrypi systemd[1]: Starting Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator...
мар 11 14:15:29 raspberrypi hostapd[1309]: Configuration file: /etc/hostapd/hostapd.conf
мар 11 14:15:29 raspberrypi hostapd[1309]: wlan0: Could not connect to kernel driver
мар 11 14:15:29 raspberrypi hostapd[1309]: Using interface wlan0 with hwaddr b8:27:eb:5c:49:c7 and ssid "Rpi_ap"
мар 11 14:15:29 raspberrypi hostapd[1309]: wlan0: interface state UNINITIALIZED->ENABLED
мар 11 14:15:29 raspberrypi hostapd[1309]: wlan0: AP-ENABLED
мар 11 14:15:29 raspberrypi systemd[1]: Started Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
UPD2:
New data. if I set static ip address for wlan0 in /etc/networks/interfaces and then reboot i have access point after boot. If set static ip address by command "ifconfig wlan0 192.168.5.1 netmask 255.255.255.0 broadcast 192.168.5.255" i have no access point after "sudo systemctl start dnsmasq.service" and "sudo systemctl start hostapd.service".
cat /etc/default/hostapd-sudo service hostapd status-- Did you follow this procedure? – M. Rostami Mar 11 '20 at 10:14/etc/hostapd/hostapd.confin a wrong way. Check/Change the channel. Also, check the/etc/hostapd/hostapd.confon this answer. – M. Rostami Mar 11 '20 at 11:47/etc/default/hostapdconfigured well, you don't need to runsudo hostapd -d /etc/hostapd/hostapd.conf. Just starthostapdservice bysudo service hostapd start/restart. – M. Rostami Mar 11 '20 at 11:49/etc/networks/interfaces, the OS is obsolete like Jessie, right? – M. Rostami Mar 11 '20 at 12:26dnsmasqneeds an IP address for the interface that you set there. Therefore, you set the IP address forwlan0at boot thendnsmasqor other packages will start without any problem. (guess) – M. Rostami Mar 11 '20 at 12:29wlan0(RPi Wi-Fi card) for your client and your AP ? – Ephemeral Mar 11 '20 at 12:51
