Directly coming to the point.
I bought a raspberry pi zero w from a local retailer. I burned a raspbian "buster" image (dated 2019-09-26) into a 16GB SanDisk Class 10 SDHC memory card and booted the pi. Everything was working seamlessly. I updated the pi via terminal using sudo apt update and sudo apt dist-upgrade (commands were similar to this as I upgraded 20 days ago). When upgrading I interrupted the upgrade 2-3 times but the upgrade was installed successfully. Later on, I kept the pi as it is for some days and again booted it after a few days.
Then I noticed that my pi is unable to connect to my WiFi network. It was showing No wireless interfaces found then I searched on SO forum for
Connect to WiFi network through Ubuntu terminal [duplicate]
I run the command ifconfig wlan0 and the result was
wlan0: flag=4098<BRADCAST,MULTICAST> mtu 1500
ether b8:27:eb:db:be:ea txqueue len 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
Then I ran the sudo ifconfig wlan0 up command and it said SIOCSIFFLAGS: Input/Output error. Then I checked another solution of Is there a terminal command to verify if Wifi is enabled?
and ran the command rfkill list to check whether wifi has any soft or hard block but as output said there was no soft or hard block to neither Wireless LAN nor Bluetooth. After more research, I updated the wpa_supplicant.conf file and tried many solutions like entering the network configuration, entering country code, again removing the network configuration after entering country code, etc. but nothing worked. Then I ran command iwlist wlan0 scan stated in the
RPi 3 B+ Wifi not working and the output was
wlan0 Failed to read scan data : Network is down.
Then I ran raspi-config to change the wifi country but the output was Could not communicate with wpa_supplicant. Later on, I tried many solutions found in various communities.
I tried commands like
sudo rfkill unblock all
sudo killall wpa_supplicant
sudo wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
sudo wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -d
Nothing worked in my case. I tried re-installing the raspbian but that also failed. Then I changed the /etc/network/interfaces file and added
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "network-name"
wpa-psk "network-password"
And the result was the same. After so many tries of 4 days, I decided to ask the question on SO. Is WiFi of my pi is broken? or there is any other solution that will work.
Edit1: Today I noticed that I can't even connect my Pi Zero W via Bluetooth. Is there some serious issue regarding hardware?
Edit 2:
I bought a WiFi dongle and connected it with my Pi using a multiport USB connector. By running sudo iwlist wlan1 scan command, my WiFi dongle is able to scan the network but could not connect through GUI.
Any help is warmly appreciated. If you need more information, please ask for it.
Thanks in advance.
ls /sys/class/net/show? – Milliways Mar 10 '20 at 07:38lo wlan0– Vaibhav Mandlik Mar 11 '20 at 16:58
