Im trying to connect my pi 4 to the wifi via editing the boot file on the sd card. the wifi is a hidden network The following i tried to do, see picture.
the file name is [wpa_supplicant.conf] i added this file on the sd
update_config=1
country=NL
network={
ssid="Hyperloop 2.4g"
scan_ssid=1
key_mgmt=WPA2-PSK
psk="xxxmywifipaswordxxx"
Im wondering what i do wrong because i cant find the device on the network. I use an app to find devices that are connected to the network.
Thanks in advance
wpa_cli
to setup your connection. – Swedgin Mar 03 '20 at 10:11hyperloop
andNL
gave it away. But do you have terminal access or is the pi running headless?; No GUI is not the same as headless – Swedgin Mar 03 '20 at 10:22
