I'm aware of streaming live video using on the RaspberryPi itself as a server. But is there a way to send the video from the raspicam to an external web-streamer so that if I have multiple people viewing a stream it doesn't use up the resources of the pi? What protocol and server should i use? My raspberry is a raspberry pi zero w and i want to stream at the local network via wifi. Thanks.
            Asked
            Active
            Viewed 2,375 times
                    does the external web-streamer accept input streams? – jsotola Feb 19 '20 at 23:05
                    Yes thats the point that it should accept the video stream from the raspberry. The plan is : Raspicam -> server(gateaway)->multiple clients(web browsers). – NIKOS MITRO Feb 20 '20 at 08:33
        There is a lot of camera streamer tools/package and I have tested almost all of them then deduced the motion is the better one. It has a simple stream web page and the key advantage is the configuration file.
Motion installation:
You can install it simply by:
sudo apt-get update
sudo apt-get install motion
Motion configuration:
Check this link - (/etc/motion/motion.conf) out.
        M. Rostami
- 4,323
 - 17
 - 36
