I realized that i can plug my web camera to raspberry pi. now i'm looking for a way to stream it on a web page. also i want to get streams over internet.
are them possible? how can i install it? thanks.
Asked
Active
Viewed 3,386 times
Lymia
- 23
- 2
- 6
1https://www.linux-projects.org/uv4l/ – goldilocks Feb 15 '20 at 20:12
I use MotionEyeOS but if you also want to use your pi for other stuff you can just install MotionEye
Bra1n
- 1,251
- 7
- 7
You can install the motion
package on your Raspbian Buster to stream the camera's frames. Simply install it by apt-get install motion
After the installation, try to configure it by changing values on /etc/motion/motion.conf
. If you just want to stream the frames without any feature else, try these lines there:
stream_localhost off
stream_port 8081
daemon on
#webcam_localhost on
#webcam_port 8080
Then, run motion
on the terminal and open up this web page address on the other motions web browser:
http://raspberrypi:8081
You'll see a page with the raspberry pis camera frames/streams. If you are concerned about the security of motion, check this link out. Also, more configuration options are here in this link.
M. Rostami
- 4,323
- 17
- 36
can i open the web page stream on localhost after adding
? – Lymia Feb 16 '20 at 09:56 -
1Yes, it's just for disabling vice versa host to localhost. If it's
on
you can open the web page by localhost and when it'soff
, all host (include localhost) can open it up. – M. Rostami Feb 16 '20 at 10:04
