It appears that after a kernel update happened, and rebooted for, Raspbian will no longer boot. (RPi4) After entering the (correct) encryption key when prompted, the mount fails with error:
Cannot initialize device-mapper. Is dm_mod kernel module loaded?
If I CTRL+C enough I can drop to a BusyBox shell and attempt to cryptsetup manually, but that has the same problem, even after trying modprobe dm_mod, so I don't think that the device mapper kernel module is being included in the initramfs at all.
I can remove the SD card and mount it without issue in a different Debian PC, and am able to read/write the file system, including installing packages via apt and rebuilding the initramfs. The process I'm using to do this is:
# replace /dev/sdf with your SD card block device
# make sure you do that for the two `sed` calls for "/etc/crypttab" too!
# mount
cryptsetup -v luksOpen /dev/sdf2 sdcard
mount /dev/mapper/sdcard /mnt; mount /dev/sdf1 /mnt/boot; mount -o bind /dev /mnt/dev; mount -o bind /dev/pts /mnt/dev/pts; mount -t sysfs none /mnt/sys; mount -t proc none /mnt/proc
# comment out ld.so.preload
sed -i 's/^/#/g' /mnt/etc/ld.so.preload
# crypttab needs to point to the current physical device during mkinitramfs or cryptsetup won't deploy
sed -i 's/mmcblk0p/sdf/g' /mnt/etc/crypttab
# copy qemu binary
cp /usr/bin/qemu-arm-static /mnt/usr/bin/
# chroot to Raspbian to update and rebuild initramfs
chroot /mnt /bin/bash
rm -rf /var/tmp/mkinitramfs*
apt update && apt upgrade && apt dist-upgrade && apt autoremove
test -L /sbin/fsck.luks || ln -s /sbin/e2fsck /sbin/fsck.luks
mkinitramfs -o /boot/initramfs.gz -k $(ls -t /lib/modules | tail -1)
exit
# undo damage
sed -i 's/^#//g' /mnt/etc/ld.so.preload
sed -i 's/sdf/mmcblk0p/g' /mnt/etc/crypttab
# unmount
sync
umount /mnt/{dev/pts,dev,sys,proc,boot} /mnt
cryptsetup -v luksClose sdcard
These instructions have gone through revisions to try and resolve this. Most notably the "crypttab" replacement from "mmcblk0p" to "sdf", which is only there so when mkinitramfs runs within a chroot the encrypted partition is found. Otherwise the process shows "cryptsetup: ERROR: Couldn't resolve device /dev/mmcblk0p2". (Either value give the same error when really trying to boot.)
The boot command line "/boot/cmdline.txt" refers to the encrypted partition correctly:
console=serial0,115200 console=tty1 root=/dev/mapper/sdcard cryptdevice=/dev/mmcblk0p2:sdcard rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet plymouth.ignore-serial-consoles
Kernel version going on is "4.19.97-v8+" though I've tried "4.19.97+", "4.19.97-v7+", and "4.19.97-v7l+" too.
Other than a reinstall, would you have any advice on building a good initramfs to resolve this encryption issue?
Related questions:
mknod/dev/mmcblk0p1to/dev/sdf1and so on for the other partitions if you wanted to avoid all the sed stuff. Basically you have to figure out how to get the missing module into the initramfs. Most distros have a config file you can edit to list additional modules that should be included, e.g. this one for Ubuntu which might give you some hints. If you can figure that out, regenerating the initramfs as you've done should be all you need to get the system going again. – Malvineous Feb 14 '20 at 14:04initrd=is still the kernel parameter used to indicate the path of an external initramfs (which is why I wrote "any kind of" -- anyway, they're normally not compiled in, if you have a normal linux box, go look at the grub2 config, it will be usinginitrd=/path/to/initramfs). "it's impossible to build a modern kernel without initramfs": Enabling and building them is still an option; I'm on an x64 box with a custom 5.4 kernel built by me, no initramfs. The major reason for using an initrd/ramfs is to facilitate loading of drivers... – goldilocks Feb 15 '20 at 14:35/lib/modules; this is also the reason you need one with an encrypted filesystem -- unless you built the encryption drivers into the kernel). These drivers need to cover a range of commonplace hardware (and fs types), and it is not convenient to build them all into the kernel, hence the initramfs. Which also means you can build an initramfs and use it without rebuilding the kernel. – goldilocks Feb 15 '20 at 14:36/boot/config.txt(as opposed to thecmdline.txtmethod I mentioned). – goldilocks Feb 15 '20 at 14:36/boot/config.txtto see if there is any reference to aninitramfsin there. If not, I think this is a problem. – goldilocks Feb 15 '20 at 16:03initrdparameter and it will overwrite whatever is included in the built in (and possibly empty) initramfs. Of course now that I think about it it seems obvious, having to patch a precompiled kernel with a user-specific initramfs would be a huge headache! – Malvineous Feb 16 '20 at 09:17mkinitramfs. – Adambean Feb 16 '20 at 10:03initramfsreference, as "initramfs initramfs.gz followkernel". "initramfs.gz" exists with a modified timestamp matching when I last ranmkinitramfs. – Adambean Feb 17 '20 at 08:08insmod $(find /usr -type f -name "*dm-mod*")that it returned "insmod: can't insert ......: invalid module format". The only major difference in steps taken I can see is inserting extra kernel modules into "/etc/initramfs-tools/modules" and runningupdate-initramfs -uprior to building, along with the symlinks to mmcblk. Not sure who's answer I should be accepting :) – Adambean Feb 17 '20 at 16:22
