I’m trying to figure out how to record the system audio from raspbian. I want to record audio from either the OS or a specific program... like recording an audio stream... if it possible? I tried searching but everything is talking about using a USB sound card. Any help is appreciated.
Asked
Active
Viewed 3,344 times
Your question is not very clear. What sort of audio signal do you wish to record. Is it your human voice input to a microphone, and you want to convert it into an mp3 file. Or do you wan to convert and analog signal output from a microphone input to the USB sound card, and convert it to digital signal stream? And what is the longest time of audio you want to record, say less than 10 seconds, or longer than 1 hours. And what is the sound quality you wish, say mp3, VCD, 44.1kHz sampling rate or higher? – tlfong01 Feb 11 '20 at 05:34
For DIY hobbyists, usually the first thing to try is using an low resolution 10/12 bit ADC, say converting a microphone pre amp output to digital signals using MCP3008, or using dirt cheap HiFi ADC module such as: PCM1802: https://raspberrypi.stackexchange.com/questions/107778/how-to-use-rpi-python-to-control-pcm1802-24-bit-hifi-stereo-adc-and-max4466-micr. – tlfong01 Feb 11 '20 at 05:37
you are welcome. Happy recording. Cheers. – tlfong01 Feb 11 '20 at 08:32
You can store all speaker output by this procedure.
Install these packages:
sudo apt-get install pulseaudio-utils lame
Search for your speakers and tap into your speaker's monitor stream:
pacmd list-sinks | grep -e 'name:' -e 'index' -e 'Speakers'
Find the monitor stream by:
pacmd list-sources | grep -e 'name:' -e 'index'
Play anything you want to record and run this command with your alsa monitor output:
parec -d alsa_output.pci-0000_00_1f.3.analog-stereo.monitor | lame -r -V0 - OutputAudio.mp3
Hit
ctrl+c
to stop recording. Play theOutputAudio.mp3
M. Rostami
- 4,323
- 17
- 36
1Thanks @M.Rostami I’ll give that a try. I’m sorry if I didn’t make the question clearer. Your answer is exactly what I am trying to do. Thanks again. – randbasic Feb 11 '20 at 07:33
Thanks too much. Your answer helped me too, I'm trying to record sys audio with microphone audio in the same time is it possible using lame & parec? – Mamdouh Saeed Mar 26 '21 at 21:44
