I have a problem with my Raspberry Pi 4B running Raspbian
When I boot it, internet through wifi works, but after some hours (between 6 and 24 hours, approximately), wifi is still working but nothing works. Web pages are not found, pinging doesn't get any response, apt is not able to download anything, I can't ssh nor vnc my Pi 4B, etc...
I also have a Raspberry Zero and I don't have any problem with it.
When connectivity works, I have this output:
pi@raspberrypi:~ $ sudo ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether dc:a6:32:22:b9:84 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
RX packets 9 bytes 524 (524.0 B)
TX packets 9 bytes 524 (524.0 B)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.68 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::a091:e8d0:2ce:89e3 prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:22:b9:85 txqueuelen 1000 (Ethernet)
RX packets 91025 bytes 136099814 (129.7 MiB)
TX packets 35550 bytes 3194179 (3.0 MiB)
pi@raspberrypi:~ $ sudo route -n
Kernel IP routing table
0.0.0.0 192.168.1.1 0.0.0.0 UG 303 0 0 wlan0
192.168.1.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
pi@raspberrypi:~ $
But when the connectivity is lost, the state of the net is the following:
RX packets 5018 bytes 676532 (660.6 KiB)
TX packets 5018 bytes 676532 (660.6 KiB)
inet 169.254.197.68 netmask 255.255.0.0 broadcast 169.254.255.255
RX packets 18856 bytes 3990231 (3.8 MiB)
TX packets 2883 bytes 228805 (223.4 KiB)
0.0.0.0 0.0.0.0 0.0.0.0 U 303 0 0 wlan0
169.254.0.0 0.0.0.0 255.255.0.0 U 303 0 0 wlan0
pi@raspberrypi:~ $
So, I've lost the gateway in the wlan interface according to the route command. I'm sure that the problem is related to this. Some people has the problem that the net interface changes to the eth0 interface, but not in this case.
I'm using the official 3A power supply, so that shouldn't be the problem.
Someone has a clearer idea of what to try?
EDIT 1:
The following commands provide extra information:
pi@raspberrypi:~ $ systemctl status dhcpcd.service
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2020-02-08 21:58:54 CET; 1 day 23h ago
Process: 351 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SUCCESS)
Main PID: 395 (dhcpcd)
Tasks: 2 (limit: 4915)
Memory: 4.9M
CGroup: /system.slice/dhcpcd.service
├─395 /sbin/dhcpcd -q -b
└─503 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
Feb 10 21:01:13 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:02:16 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:03:21 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:04:24 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:05:28 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:06:33 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:07:37 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:08:41 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:09:44 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 10 21:10:49 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Also this other command:
pi@raspberrypi:~ $ journalctl --boot --unit=dhcpcd.service
-- Logs begin at Sat 2020-02-08 21:58:50 CET, end at Mon 2020-02-10 21:20:04 CET. --
Feb 08 21:58:53 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Feb 08 21:58:54 raspberrypi dhcpcd[351]: dev: loaded udev
Feb 08 21:58:54 raspberrypi dhcpcd[351]: forked to background, child pid 395
Feb 08 21:58:54 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Feb 08 21:58:55 raspberrypi dhcpcd[395]: wlan0: connected to Access Point `'
Feb 08 21:58:55 raspberrypi dhcpcd[395]: eth0: waiting for carrier
Feb 08 21:58:55 raspberrypi dhcpcd[395]: wlan0: waiting for carrier
Feb 08 21:58:55 raspberrypi dhcpcd[395]: wlan0: carrier acquired
Feb 08 21:58:55 raspberrypi dhcpcd[395]: DUID 00:01:00:01:25:1e:c6:d7:dc:a6:32:22:b9:85
Feb 08 21:58:55 raspberrypi dhcpcd[395]: wlan0: IAID 32:22:b9:85
Feb 08 21:58:55 raspberrypi dhcpcd[395]: wlan0: adding address fe80::8d8f:2125:37e7:18b6
Feb 08 21:58:55 raspberrypi dhcpcd[395]: wlan0: carrier lost
Feb 08 21:58:55 raspberrypi dhcpcd[395]: wlan0: deleting address fe80::8d8f:2125:37e7:18b6
Feb 08 21:59:00 raspberrypi dhcpcd[395]: wlan0: carrier acquired
Feb 08 21:59:00 raspberrypi dhcpcd[395]: wlan0: connected to Access Point `MiFibra-56BA'
Feb 08 21:59:00 raspberrypi dhcpcd[395]: wlan0: IAID 32:22:b9:85
Feb 08 21:59:00 raspberrypi dhcpcd[395]: wlan0: adding address fe80::a091:e8d0:2ce:89e3
Feb 08 21:59:00 raspberrypi dhcpcd[395]: wlan0: soliciting an IPv6 router
Feb 08 21:59:01 raspberrypi dhcpcd[395]: wlan0: rebinding lease of 192.168.1.68
Feb 08 21:59:01 raspberrypi dhcpcd[395]: wlan0: probing address 192.168.1.68/24
Feb 08 21:59:06 raspberrypi dhcpcd[395]: wlan0: leased 192.168.1.68 for 86400 seconds
Feb 08 21:59:06 raspberrypi dhcpcd[395]: wlan0: adding route to 192.168.1.0/24
Feb 08 21:59:06 raspberrypi dhcpcd[395]: wlan0: adding default route via 192.168.1.1
Feb 08 21:59:14 raspberrypi dhcpcd[395]: wlan0: no IPv6 Routers available
Feb 09 18:59:47 raspberrypi dhcpcd[395]: wlan0: failed to renew DHCP, rebinding
Feb 09 18:59:48 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 18:59:51 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 18:59:59 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 19:00:14 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 19:00:46 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 19:01:50 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 19:02:53 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:54:52 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:55:56 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:57:00 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:58:04 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:59:09 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:59:47 raspberrypi dhcpcd[395]: wlan0: DHCP lease expired
Feb 09 21:59:50 raspberrypi dhcpcd[395]: wlan0: deleting route to 192.168.1.0/24
Feb 09 21:59:50 raspberrypi dhcpcd[395]: wlan0: deleting default route via 192.168.1.1
Feb 09 21:59:50 raspberrypi dhcpcd[395]: wlan0: soliciting a DHCP lease
Feb 09 21:59:50 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:59:54 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 21:59:55 raspberrypi dhcpcd[395]: wlan0: probing for an IPv4LL address
Feb 09 21:59:55 raspberrypi dhcpcd[395]: arp_probe1: No buffer space available
Feb 09 21:59:57 raspberrypi dhcpcd[395]: arp_probe1: No buffer space available
Feb 09 21:59:58 raspberrypi dhcpcd[395]: arp_probe1: No buffer space available
Feb 09 22:00:00 raspberrypi dhcpcd[395]: wlan0: using IPv4LL address 169.254.197.68
Feb 09 22:00:05 raspberrypi dhcpcd[395]: wlan0: adding route to 169.254.0.0/16
Feb 09 22:00:05 raspberrypi dhcpcd[395]: wlan0: adding default route
Feb 09 22:00:05 raspberrypi dhcpcd[395]: arp_announce1: No buffer space available
Feb 09 22:00:05 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 22:00:07 raspberrypi dhcpcd[395]: arp_announce1: No buffer space available
Feb 09 22:00:22 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 22:00:55 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 22:01:59 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 22:03:03 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 22:04:06 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 22:05:11 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
Feb 09 22:06:16 raspberrypi dhcpcd[395]: wlan0: bpf_send: No buffer space available
And goes on forever...
EDIT 2:
Trying to renew the lease produces this error:
pi@raspberrypi:~ $ sudo dhclient -v wlan0
Internet Systems Consortium DHCP Client 4.4.1
Copyright 2004-2018 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/dc:a6:32:22:b9:85
Sending on LPF/wlan0/dc:a6:32:22:b9:85
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
send_packet: No buffer space available
dhclient.c:2445: Failed to send 300 byte long packet over wlan0 interface.
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
^C
pi@raspberrypi:~ $
– Milliways Feb 10 '20 at 00:55dhcp-lease-time
is incat /var/lib/dhcp/dhclient.leases
– Milliways Feb 10 '20 at 01:08dhcpcd
, or are you runningdhclient
? I am under the impression that you use one - or the other. – Seamus Mar 25 '21 at 05:11
