Does the Raspberry Pi 4 have a hardware watchdog timer like the RPi3 does? If it does, which kernel module should I load in order to use it?
I'm running Raspbian Buster, kernel 4.19.93-v7l+
Thanks.
Thanks.
To check if the watchdog is available, you can run wdctl
which gives you a bit more info than just looking at /dev/watchdog
To start using the watchdog, you can still use the old watchdog
daemon mentioned in the other answers, but since 2012 systemd
has had built in support for watchdogs that doesn't require installing anything else and offers better compatibility with the shutdown/reboot process.
To use this, edit /etc/systemd/system.conf
and set these values as required:
RuntimeWatchdogSec
- reboot the system if nothing contacts the watchdog within this time (specify the value like 2min
, 10s
, etc.) This defaults to off
, meaning the system will never reboot when it freezes. For Raspberry Pi, this value must be shorter than 15s to avoid a reboot loop in present kernels (driver patch in progress - Dec 2023).RebootWatchdogSec
- different timeout used when rebooting, in case you need more (or less) time. Defaults to 10min
. Note that this only applies during the last phase of the reboot, once all running programs have been terminated. If your programs take too long to shut down, this value won't help (see below).ShutdownWatchdogSec
- this is no longer used, it was renamed to RebootWatchdogSec
in July 2019.KExecWatchdogSec
- ignore this unless you know what kexec is and you know you are using it. (It's used when faking a reset by just restarting the kernel - the lack of a hardware reset means the watchdog is still running and may expire before everything has finished loading again).WatchdogDevice
- this can be ignored as the default of /dev/watchdog
is fine.DefaultTimeoutStopSec
- how long to wait for each program to exit when shutting down or rebooting. Defaults to 90s
but I am impatient so I set this to 10s
as anything on my system that takes longer than five seconds is broken, so a 10 second timeout is just fine.If you are using a Pi 2 or older, set dtparam=watchdog=on
in /boot/config.txt
and reboot. This is enabled by default from the Raspberry Pi 3 onwards, so you can skip this step with recent models.
You don't need to run systemctl enable watchdog
(that's for the old method mentioned above) but you will need to run systemctl daemon-reload
(or reboot) after making these changes before they will take effect.
would work, the system was rebooting because no watchdog was being updated. I looked further and there is no watchdog service/unit file as the system complains when running systemctl status watchdog
gives Unit watchdog.service could not be found
. Are you sure something isn't supposed to be installed? Or do you have an example Unit file that can be created for the watchdog service?
– ScottN
Jul 13 '20 at 23:56
RuntimeWatchdogSec
to 60s
– starbeamrainbowlabs
Feb 07 '23 at 01:04
For the RaspberryPi4 it's more straightforward than for earlier software as much of the configuration scaffolding is already in place.
Edit /etc/systemd/system.conf adding the line
RuntimeWatchdogSec=15
then reload systemd's configuration with the command sudo systemctl daemon-reload
Do not use values greater than 15 seconds, as that's the limit for the RPi4's countdown timer.
Optionally, if you want the watchdog timer to also detect systemd crashing then edit /boot/cmdline.txt to add to the existing line the new kernel parameter
bcm2835-wdt.nowayout=1
then reboot the system with the command sudo systemctl reboot
Do NOT attempt to load ANY modules.
Add dtparam=watchdog=on
to config.txt
and Device Tree will load the module.
NOTE you also need to enable the watchdog service. See https://raspberrypi.stackexchange.com/a/68332/8697
config.txt
on a Pi 2 and earlier. It is on by default since the Pi 3. There is nothing wrong with loading any modules. If the hardware is not present the module will just return an error. However most modules will load automatically, so if you do feel the need to load them yourself, you are probably heading down the wrong track.
– Malvineous
Jun 06 '20 at 11:33
Ok, after some testing it seems like the watchdog module is loaded by default.
To check for yourself, see if /dev/watchdog
exists.
This is the guide what worked for me.
bcm2835_wdt
. Altough maybe the preferred way is to use/boot/config.txt
like @Milliways sugests. – tlqmj Feb 06 '20 at 12:21
