I have installed an infrared emitter with the following tutorial:
https://www.instructables.com/id/Zero-to-Air-Conditioner-Controller-With-Raspberry-/
But I had trouble running the LIRC commands, so with the help of the pigpio library and this script in Python:
IR Record and Playback http://abyz.me.uk/rpi/pigpio/examples.html#Python_irrp_py
I had managed to set up my air conditioning.
After backing up and reinstalling the operating system (Raspbian Buster on RP3+B) I was not able to get my air conditioning to work.
I don't know if the problem is something electrical or something at the software level. I have controlled with a camera that the emitter emits when it executed the commands. I have in turn controlled the status of the pidgpio service and it returns this to me:
sudo systemctl status pigpiod
Warning: The unit file, source configuration file or drop-ins of pigpiod.service changed on disk. Run 'systemctl daemon-reload' to reload units
● pigpiod.service - Daemon required to control GPIO pins via pigpio
Loaded: loaded (/lib/systemd/system/pigpiod.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/pigpiod.service.d
└─public.conf
Active: active (running) since Tue 2020-02-04 09:22:20 -03; 4h 5min ago
Process: 418 ExecStart=/usr/bin/pigpiod (code=exited, status=0/SUCCESS)
Main PID: 452 (pigpiod)
Tasks: 4 (limit: 2200)
Memory: 880.0K
CGroup: /system.slice/pigpiod.service
└─452 /usr/bin/pigpiod
feb 04 09:22:18 raspberrypi systemd[1]: Starting Daemon required to control GPIO pins via pigpio...
feb 04 09:22:20 raspberrypi systemd[1]: Started Daemon required to control GPIO pins via pigpio.
Any help?
Thanks!
(2) Rpi3 LIRC Library and UART IR Transceiver Setup Problem - 2019sep11 Viewed 1,000 times https://raspberrypi.stackexchange.com/questions/103452/rpi3-lirc-library-and-uart-ir-transceiver-setup-problem. / to continue, ...
– tlfong01 Feb 05 '20 at 03:39I had managed to set up my air conditioning.... did you test it thoroughly after you set it up? – jsotola Feb 06 '20 at 03:44
