Setup: RPi 4 with LAMP on IT sucks DK
My SD card is quite quick sure (it's a Class 10 too and all) but my question is this:
  • Would there be increased performance if I hosted my web-server files on a USB 3.0 HDD/SSD instead af my Class 10 SD-card on the Pi?
Anyone tried this yet?
EDIT: Another thought: If I want people to be able to upload and download larger than 1GB files wouldn't it be practical AND faster to be reading and writing these files to a DIR on the USB 3.0 SSD instead of the SD-card which is only 16GB all in all anyways and I do have 500/500 Mbit fiber line at my full disposal for the server?
IT Blacksmith
  • 63
The SDCard interface is extremely slow compared to a USB 2.0 hard disk on my RPI3Bs.
So a USB 3.0 SSD on a RPi4B is going to be even faster (USB 3.0 is faster, SSD is faster).
Dougie
  • 5,301
  • I heard something about that the USB-controller and other controllers are one and the same and therefore one controller could have problems when dealing with both the high mbit/s on the LANinterface AND transfering files to the USB 3.0 external SSD. Is this a valid thought? – IT Blacksmith Feb 02 '20 at 17:31
    The USB 3.0 controller is on a PCIe v1 interface on a RPi4, so you won't have the overlapping with the ethernet problem (unlike older RPis). – Dougie Feb 02 '20 at 18:52
  • GReat to know - thanks for clearing that up... it's been bugging me. – IT Blacksmith Feb 02 '20 at 22:51
USB flash drives can reach up 33MBytes/s, but there seem to be some limitations in the NAND itself so it will come down to the type of stick you get. However, the sd-card bus speed can reach up to 20MB/s read on the raspberry pi. So, the better choice here is a high-class USB 2.0 USB flash drive.
On the other hand, the payment would be concerned. It cost much less to buy USB 2.0 USB flash drive instead of a UHS-3/Class 10 sd-card.
In conclusion, I see little benefit in booting from a USB flash stick, the price, and the speed. Source
If you compare SD-Card and USB 2.0, the USB 2.0 port is much faster. Obviously, USB 3.0 has a much much faster speed. The USB 3.0 is approximately 10 times faster than USB 2.0.
You may found that SSD drives are better for hosting BUT take a look at this link.
M. Rostami
  • 4,323
  • 36
