I add new hostname to the /etc/resolve.conf but it reset after I reboot Raspberry pi.
# Generated by resolvconf
nameserver 8.8.8.8
OS is raspbian buster on raspberry pi 4.
Edit: I have to change my dns server because it has problems on the local network.
Lymia
You shouldn't manually update the resolv.conf, because all changes will be overwritten by data that your local DHCP server provides. Therefore, the network manager of Raspbian Buster has configured by /etc/dhcpcd.conf. Every configuration of this config file always is overwriting to other network config files on the OS.
All you need is that you should config your network by /etc/dhcpcd.conf as you want. In this case, follow this procedure:
nano /etc/dhcpcd.conf
Then, add this line:
static domain_name_servers=4.2.2.4 8.8.8.8
Before Raspbian Strech (I'm not sure enough), you could do that. It's some difference we have here and you must follow them to configure the network.
M. Rostami
  • 4,323
  • 36
