I am working on integrating Sim900a on Rpi3B. As usual connecting to TX->Rx, Rx->Tx (GPIO14, GPIO15 in Rpi) - following diagram from this link: How do I connect GSM SIM 900A to a Raspberry Pi 3?
When I testing using Minicom 2.7x, it shows below error. My minicom setting using serial /dev/ttyS0
and baudrate 9600 (as baudrate 15200 got jammed the console and no response)
raspberrypi login:
raspberrypi login:
raspberrypi login:
raspberrypi login:
raspberrypi login:
raspberrypi login:
raspberrypi login:
ERROR
The error occurs even before typing AT
command and it loop the error many times.
I tried to connect the Sim900A module to UART->USB converter, and connect to Windows 10 laptop, tested it using Putty, COM7 with baudrate 9600, It all works well.
Any solution?
Additional info on my Sim900a: Manufacture: Simcom Model:SIM900A S2-104V-Z094T
