I am trying to set up an ad-hoc network of Pis (not connected to the Internet). I am able to ping and ssh among the Pis by changing the /etc/network/interfaces file by adding the lines to each Pi by setting a static IP address:
auto wlan0
iface wlan0 inet static
address 192.168.1.1
netmask 255.255.255.0
wireless-channel 1
wireless-essid CTWifi
wireless-mode ad-hoc
Now I am trying to set up a DHCP server so IP addresses are dynamically allocated when they connect to the ad hoc network. I was following this video: https://www.youtube.com/watch?v=5BkfztZ0pOE and was able to connect to the ad hoc network from my Windows laptop.
However, I am not able to ping or ssh the Pis from my laptop. It seems that there is no IP address allocated to my laptop so I assume that the DHCP server is not working.
I added the following lines to the /etc/dhcp/dhcpd.conf file to set configure the DHCP subnet configuration:
authoritative;
subnet 192.168.1.0 netmask 255.255.255.0 {
range 192.168.1.2 192.168.1.254;
option domain-name-servers 8.8.8.8;
option domain-name "CTWifi";
option routers 192.168.1.1;
option broadcast-address 192.168.1.255;
default-lease-time 600;
max-lease-time 7200;
I also uncommented the following lines in the /etc/default/isc-dhcp-server file to start the DHCP server:
DHCPDv4_CONF=/etc/dhcp/dhcpd.conf
DHCPDv4_PID=/var/run/dhcpd.pid
INTERFACESv4="wlan0"
When I connect to the network, my computer does not have an IP address designated to it, so I assumed the DHCP server is not working
When I attempt to the ping the Pis, it seems to keep the old IP address from the previous connection (192.168.0.6 , my own Wifi connection)
The settings are configured to have the IP address automatically allocated by the DHCP server, but it is not working, so I tried to set it manually, but it still keeps the old IP address and the manually set one.
I followed the steps in the video exactly, but I am confused about what I am doing wrong. Any help will be appreciated. Thanks
dnsmasq
. – M. Rostami Jan 14 '20 at 11:06hostapd
. – M. Rostami Jan 14 '20 at 11:12
