I'm trying to setup an ad-hoc network (intranet-only, no internet) of RPi4s (Buster 2019-09-26) using dongles with detachable antennas. I can successfully
- setup ad-hoc modes on the internal WiFi (both 2GHz and 5GHz) and add
babeld
on top of it. - get internet from a WiFi USB dongle (used
MrEngman
scripts to install drivers).
But I can't get ad-hoc to work on the dongles though - I set things up same as for wlan0
but packets don't go through. Searching around indicates it's probably the dongle that can't do ad-hoc.
My question is: what is the attribute I should look for in a dongle? So far all were using the rtl8822bu
, is that the culprit? How can I check ahead of time if a chipset will work? I don't mind scouring the internet looking for the right dongle, but I'm not sure what makes the right one right or why.
Current setup process in case it's not a hardware issue:
wlan0
Setup interfaces
sudo systemctl stop dhcpcd.service
sudo ifconfig wlan0 down
sudo nano /etc/network/interfaces
Make it look like
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
iface wlan0 inet static
address xxx.xxx.xx.xx
netmask 255.255.255.0
wireless-channel 44
wireless-essid my_net
wireless-mode ad-hoc
Then reboot
sudo ifconfig wlan0 up
sudo reboot
Do this for each Pi, changing the static IP, and you have an ad-hoc network!
wlan1
Connect to the internet using wlan0
, plug dongle in, then run
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
sudo install-wifi
You can now connect to the internet through your dongle! Now follow the wlan0
steps but set it up for wlan1
(and add iface wlan0 inet dhcp
to the interfaces
file).
EDIT
Output from sudo iw list | grep -A 12 -i "valid interface combinations"
Supported interface modes
* IBSS
* managed
* AP
* P2P-client
* P2P-GO
Band 1:
Capabilities: 0x1963
RX LDPC
HT20/HT40
Static SM Power Save
RX HT20 GI
RX HT40 SGI
* IBSS
* managed
* AP
* P2P-client
* P2P-GO
* P2P-device
Band 1:
Capabilities: 0x1022
HT20/HT40
RX HT20 GI
No RX STBC
sudo iw list | grep -A 12 -i "supported interface modes"
– Milliways Jan 13 '20 at 05:13grep
showed 2 bands, not sure if that matters. – Antoine Zambelli Jan 13 '20 at 10:50install-wifi
scripts shown with thatwget
, they're posted in several places. They find the right drivers for the kernel version. – Antoine Zambelli Jan 13 '20 at 13:57babeld
...in 2.4GHz. I gave up on 5GHz mode. Not sure if that saves somebody a headache. – Antoine Zambelli Aug 14 '22 at 21:37
