I've encountered the following problem: when I connect 1 external usb hdd to my Pi, everything works fine. But when I connect second one with the same characteristics, both drives are not usable. I believe the problem is with drives' power consumption: each hard drive draws 1A from the USB port and as far as I understand raspberry pi3+ provides 1.2A to all the four usb-ports and this is maximum current available.
Is there a way to solve this problem (my current sata-USB cases DOES NOT have an external power supply, but if they had, would this help)? Ideally I'd like to connect four drives, but even two would be cool.
Ivan
  • 43
  • My answer to the following question might help: https://raspberrypi.stackexchange.com/questions/103784/can-a-raspberry-pi-4-power-an-external-hd – tlfong01 Jan 04 '20 at 13:43
    Use an external powered hub. – goldilocks Jan 04 '20 at 16:43
  • yeap. usb-hub with external power supply does the trick, thanks. (I thougth those things were cheap but they are actually not. ~30 bucks for one) – Ivan Jan 05 '20 at 12:14
  • Please make an answer for the solution and accept it after two days. Only this will finish the question and it will not pop up again and again for years. – Ingo Jan 06 '20 at 08:14
I have solved the problem by connecting all the USB HDDs through the usb-hub with external power supply.
Ivan
  • 43
