I've had my Raspberry Pi 3B+ for a while now (a couple of months, maybe) and it has always booted just fine, up until this week. I was using the RPi to host my Discord Bot, but now it doesn't seem to boot and/or connect to the network. The device runs on Raspbian through NOOBS.
Symptoms
  • The device's PWR indicator remains a solid red
  • The device DOES show ACT indicator blinking at startup
  • The Two(2) LEDs on the ethernet port light up ever so slightly (no cable)
  • The device cannot be found on the network
  • VNC Server is not listening for cloud connections
At the time of posting i have read the entire Pi Not Booting page to no avail.
Delta
you will need to do a filesystem check & repair:
Start the Raspberry holding the Shift key.
Once NOOBS loads, press Alt-F2 to access the recovery command line...
I had the same problem but with unknown-block(179.7) and the first solution worked fine, just replacing this:
<p><code>sudo fsck.ext4 -y /dev/mmcblk0p6</code></p>
<p>with this:</p>
<p><code>sudo fsck.ext4 -y /dev/mmcblk0p7</code></p>
<p>I'm not an expert but hope this could help others.</p>
See more here
Delta
