I have a PSU from Amazon that provides 5V and I used my trusty multimeter to adjust the voltage to exactly 5.0V. I used it previously to run some silent fans, but I don't have any use for that anymore now.. Time to see if I can use it for the Raspberry. It gets 5V through the charger and the PSU gives up to 5A..
Now when I read the schematics on https://www.raspberrypi.org/documentation/hardware/raspberrypi/schematics/ for the Raspberry Pi 3 Model B+, I can connect the Pin 1 of J1 (Power in, 5V-) through PP2 and Pin 5 (Power in, GND) with either PP3, PP4, PP5 or PP6.
I have soldered a small wire with a dupont connector to PP2 and PP3. However, when I attach the PSU to it, nothing happens. I have double checked - the Pi turns on with the regular charger and the wires are properly connected.
Can you give me any suggestions how to make this work?
Powering Raspberry PI With Broken Micro USB Connector - 2019jan https://raspberrypi.stackexchange.com/questions/76653/powering-raspberry-pi-with-broken-micro-usb-connector. – tlfong01 Dec 07 '19 at 03:16
