12
I am trying to install tightvncserver on my rPi model A running Raspbian. I am connecting to the rPi via SSH from my laptop. I can connect to the internet, but cant install the package. It seems to be a problem with mirrordirector.raspbian.org because that is where my rPi runs into trouble. Is anybody else running into this issue or found a solution? Searching this site seemed to show that I am not alone in this, but I couldn't find a resolution.
I've tried
sudo apt-get update
Screenshot: Screenshot for sudo apt-get update
but it takes forever when trying to reach mirrordirector.raspbian.org Every time I try it says "XX% [waiting for headers]" for several(30+) minutes before finishing with an error message.
I've tried pinging mirrordirector.raspbian.org with both my rPi and laptop, and both tell me its unreachable. When I try to go there with my browser(on laptop) it gives me error 504 gateway timeout.
Edit: I tried wget mirrordirector.raspbian.org and it gave me a 504 error... Is anybody else getting this error? wget output on rPi
Should I change my sources.list file? it contains
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free r$
Ghanima
  • 15,855
  • 119
Awsumman
  • 149
  • I have the same issue. Do you use a Netgear router? – Vreality Jan 28 '14 at 21:37
  • Be sure to check that there is not a firewall rule blocking your attempted connection. – anonymous164937 May 25 '15 at 03:07
  • The question is old but I had same problem today of being able to ping but not to get data with wget also from google.com so here my solution: after a lot of trials just to give it a try I've launched rpi-update and it worked, then after a reboot also apt-get started working. Seems crazy but so that was – Andrea Giovacchini Feb 21 '15 at 23:37
  • when i manually tried to visit the pages, i got the same problem as yours might be your Pi is out of memory or your memory card got corrupted i had the same issue, i solved this with another memory card(i expanded the momory partition) see this link in here – Ruthvik Vaila Nov 08 '13 at 14:37
  • It may be worth noting the list of Raspbian mirrors - of relevance/explanation also is the paragraph that mentions that: "The mirror redirection system is available at http://mirrordirector.raspbian.org/ . It provides the same files as http://archive.raspbian.org/ and can be used in apt sources etc. It is powered by mirrorbrain and will automatically direct requests to a suitable (and hopefully local) mirror (note: for technical reasons not all files are redirected). " MirrorBrain is a FOSS project. – SlySven Jan 18 '17 at 05:07
7 Answers7
Please note this answer is out-of-date and the current version of Raspbian is jessie, not wheezy. Make sure of which one you are using before you do anything.
Your raspbi could not find a valid mirror so you need to find a working mirror. For valid and working mirrors please check http://www.raspbian.org/RaspbianRepository
After getting valid mirror address you need to add this mirror url to your /etc/apt/sources.list
for example your sources.list file should look like
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free
and then you need to update apt sources
sudo apt-get dist-upgrade
finally update your raspbian or do whatever you want
sudo apt-get update
goldilocks
  • 58,859
  • 112
  • 227
efesaid
  • 161
I had a similar problem. It turned out that the network I was on required http requests to go through a proxy.
Usually typing the following before accessing the web will work:
pi@raspberrypi ~ $ export http_proxy="http://username:password@host:port/"
(where username:password are your username and password on the proxy, host is the name of the proxy and port is the port on the proxy. If you don't need to login to the proxy, you can leave off the username:password@ part.)
But it turns out that apt-get doesn't understand the http_proxy variable (for security reasons.)
Instead I followed the directions at http://www.raspberrypi.org/forums/viewtopic.php?f=28&t=18634
pi@raspberrypi ~ $ cd /etc/apt/apt.conf.d/
pi@raspberrypi /etc/apt/apt.conf.d $ sudo nano 10proxy
Within the nano editor type the following line:
Acquire::http::Proxy "http://username:password@host:port";
Then use ^X (Ctrl-X) to save and exit. Now
sudo apt-get update
should work.
Hello I had the same problem , I found out that in my case it is my netgear router which is blocking all ip adresses in range 5.x.x.x
so raspbian.org is blocked (I also tried www.pure.com) same result netgear is abusing range 5.x.x.x for readycloud function , very bad !!! I solved it by using wifi access in other place (without netgear router)
raspi fan
Some of the answers to this question are out-of-date now that the current version of Raspbian is jessie, not wheezy.
The content of /etc/apt/sources.list has changed accordingly. Here it is as it appears in the 2016-09-23 image:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
I had this problem with mirrordirector.raspbian.org and solved it by uncommenting the last line. Strangely, this was only necessary on one of the two SD cards I installed.
goldilocks
  • 58,859
  • 112
  • 227
I had the same(?) problem with mirrordirector.raspbian.org. I booted a new image and made a wifi connection while in the raspi-config gui. I logged out to the console and tried apt-get. No luck. In fact no internet at all. Exiting the gui killed the connection. I rebooted and this time internet working, apt-get working.
user16300
I had the same issue and found that the issue was that my /etc/resolv.conf was pointing the nameserver to an old IP address that was previously used by a workstation on my network (No idea why) after correcting that to my DNS server on my network all was wel
Kyle
  1. sudo nano /etc/apt/sources.list
  2. clear all line and add
  1. exit and save CTRL-X
  2. sudo apt-get upgrade
  3. sudo apt-get update
goldilocks
  • 58,859
  • 112
  • 227
Hamed
  • 299
