15
I am using the official 15.3W USB-C Power Supply to power up my Raspberry Pi 4.
I got my self a second Raspberry Pi 4 but I haven't bought the power supply yet. Would I be able to use the Macbook Pro 87W USB-C Power Adapter instead?
I know that some devices only ask for so much current, and the adapter will not give more than that. Not sure if that's the case with RPi 4.
Dino
  • 373
  • Simple answer - try it. You shouldn't do any harm as long as it works to the USB-C spec. Worst case is it won't boot. – Dougie Nov 26 '19 at 17:43
  • Yes, Rpi won't ask more current than it needs. But I heard that Rpi4 does not like Apple's USB-C charger. – tlfong01 Nov 27 '19 at 01:21
NOTE: Please read the Follow up, 14 Aug 2020 near the end of this post. The "Raspberry Organization" has released revised hardware for the RPi 4B that you should know about before buying.
Revised Answer:
It will not damage your RPi, but it won't work unless you use a NON e-marked USB-C cable (details follow).
The Macbook Pro 87W USB-C Power Adapter has enough power to run the RPi 4B. The specifications printed on the adapter state that its 5.2 volt output is rated at 2.4 Amps.
HOWEVER..., it seems that the Raspberry Pi designers didn't read the USB-C specs, and didn't test their design very well before releasing it to production. This has been reported in several sources, including this post on TechRepublic, this post on Hackaday, and further analyzed in this post by Tyler Ward. Or perhaps, The Foundation simply wanted to sell more of their "official" power supplies for the RPi 4B?
And so despite the fact that the Macbook Pro 87W USB-C Power Adapter (now replaced by the 96W supply) has more than ample power to handle the RPi 4, the RPi 4 is missing hardware that allows it to work with e-marked USB-C cables. A design that is compliant with the USB-C specifications will work with e-marked USB-C cables (more info); unfortunately, the Raspberry Pi 4 will not.
The reasons for this bodge are less important now than the remedies, so let's get on with that.
The (most practical) solutions are:
  1. Buy the "Official" power supply sold by the Raspberry Organization, or
  2. Get a NON e-marked USB-C cable.
I saw no reason to cause the manufacture of yet another "wall wart" that may eventually wind up in a landfill when I've already got enough USB-C cables and chargers. It's a standard - right? And so I didn't buy the "official" power supply when I bought my RPi 4. For me personally, Option 1. is a "no-go" at this point.
For Option 2, Tom's Hardware has conveniently provided a list of USB-C cables they've tested that they claim will work with the RPi 4. Tom's also expressed understanding and compassion for the Raspberry Pi organization. I don't buy it, but to each his own.
I've not tried a different cable yet, but when I do, I'll follow up here with the results. In the meantime, I did try my Macbook Pro USB-C charging cable and 87W power supply. I confirmed that it DOES NOT power up the RPi 4. Also note that after trying my Macbook cable & charger on the RPi 4, I had to unplug and re-plug my power supply before it would charge my Macbook again! Just for grins, I also tried a new-ish USB-C charger made by Apple for an iPhone (18 watts as I read the low-contrast specs printed on the charger) with the same result: the 18 watt charger with Apple charging cable DOES NOT power up the RPi 4.
Follow up, 26 Dec 2019:
I obtained an el-cheapo USB-C charging cable (aka NON e-marked cable) from Amazon. I tried this cable with my Macbook Pro 87W USB-C Power Adapter. This combination successfully powered the RPi 4B. I also tried this same cable with Apple's 18 watt iPhone charger. This combination also successfully powered the RPi 4B, and has continued to do so for more than 24 hours as of this writing.
Follow up, 14 Aug 2020:
Here's how to tell which version of the RPi4 you have (REF):
$ cat /proc/cpuinfo | grep Revision
If the result is :
  • Revision : b03111 It's an ORIGINAL RPi4 with USB-C design flaw, and a NON e-marked cable is required for use with a USB-C charger.
  • Revision : c03112 It's a newer RPi4 with the corrective fix; you may use any cable - either an e-marked cable, or a NON e-marked cable.
Seamus
  • 21,900
  • 70
    Thanks! So if I got it correctly, it should work as long as I switch to the NON e-marked USB-C cable? The power adapter may remain the one from MacBook – Dino Dec 29 '19 at 14:34
    @Dino: Yes, the power supply itself is not the issue; it's the cable (see the Follow up section above). TL;DR the USB-C spec, but it *appears* that the cable is used to signal the power supply what output voltage to suppy. E.g. when you're charging your Macbook, the PS outputs 20 VDC; when it's powering a 5 V (USB2) device, the PS outputs 5 VDC. Non e-marked cables will only allow 5 VDC. – Seamus Dec 30 '19 at 02:27
If you put an adapter (like the uni HDMI adapter with an additional USB-C line) in-between it will work too. If you have a MacBook Pro you'll have one for sure.
