I have a RPi zero W and am reading four ds18b20 temperature sensors (with a 10K ohm resistor between the data and vcc line). Now and then I keep getting "SensorNotReadyError" from the sensors.
My previous design had one sensor less and didn't have an additional LED and it worked fine. Could it be that the LED + additional sensor consume too much power? I'm using a 2A power brick. Could a 3A solve the problem? Any ideas how to read 4+ sensors with a Rpi zero?
Ah, Let me see. It is not the problem of the power from the Rpi 3v3 rail. It is the power of the 1-Wire (sort of I2C) GPIO pin trying to pull down the voltage at the pull up resistor connecting DBS18B20 input pin and Vcc. I have no problem connecting 16 DBS18B20 connected to one GPIO pin (ie, 64 DBS18B20s for 4 GPIO pins for Rpi4B) (1) https://imgur.com/gallery/9LzPqvB, (2) https://raspberrypi.stackexchange.com/questions/100203/ds18b20-temperature-sensor-rpi-3-4-driver-wiring-detection-and-python-progr, / to continue, ... – tlfong01 Nov 20 '19 at 00:25
