The Raspberry Pi 3 A+ ,I think is memory-constrained,in that Chromium does not work well. I wanted to code Scratch 3 on it as Scratch 2 is only available offline. Using the web seems off limits and so does Sonic Pi even offline. Thonny for Python is usable offline . Is there any way around this issue?. Would using some type of adaptor work e.g. Pimorono. Also, I presume it is more suited to hardware projects similar to Pi zero projects,am I right? I downloaded Raspbian via Noobs onto 16 Gb micro-sd card initially.
            Asked
            Active
            Viewed 103 times
                    Why don't you buy a Pi4 4GB? – CoderMike Oct 25 '19 at 18:40
                    Because I just got this one and I presume it will work for some purpose – Bluelion7 Oct 25 '19 at 18:42
                    It will work fine for anything that does not require lots of memory. Looks like you've had loads of suggestions on the Pi forum https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=254791 – CoderMike Oct 25 '19 at 18:45
                    Ahh! I know but it all sounds gobbledygook. I am amazed someone can track that! – Bluelion7 Oct 25 '19 at 18:54
        If you read the Foundation documentation you will see that Scratch 3 ONLY works on a Pi4 (or earlier model with 1GB RAM, but operation is marginal).
The Pi3A+ has the same memory 500MB as the earlier single CPU Pi models with a 4 core processor. It is an extremely capable machine - the only limitation is the number of simultaneous tasks.
You can certainly install Scratch 2 (which should be included in the full download).
DO NOT use NOOBS, install Raspbian.
- 31
- 101
- 209
