-1
I tried to follow some online tutorials to get my Pi to connect to a hidden network. I used the command:
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Prompting this:
update_config=1
country=GB
network={
        ssid="insert_your_hidden_SSID_here"
        scan_ssid=1
        psk="insert_your_wifi_password_here"
        key_mgmt=WPA-PSK
I ended up creating several wpa_supplicant.conf files as I was a bit confused initially what the process did. enter image description here
I have several of these files and I don't need them anymore. I tried to delete them manually just to see what would happen and I got a permission denied warning. On top of that, I wasn't able to even connect to my hidden network, so I ended up making it visible and connecting to it that way. If anyone has suggestions as to how I can remove the config files, or if I should just leave them be, and how I could properly access hidden networks, I would greatly appreciate it.
Jay P
To delete restricted files you can use rm in combination with sudo (execute with root rights). So to delete wpa_supplicant.conf you can execute on the command line:
rpi ~$ sudo rm /etc/wpa_supplicant/wpa_supplicant.conf
Repeat that with the names of the other files you want to delete. But you need wpa_supplicant.conf to connect to the hidden access point. Just recreate /etc/wpa_supplicant/wpa_supplicant.conf with the content you have shown in the question. That should do.
  • 42,107
  • 85
  • 197
It is difficult to see what you have done (post text not illegible pictures) or how you actually created multiple files, but /etc/wpa_supplicant/wpa_supplicant.conf is owned by root.
It can easily be deleted at the command line with
See How to set up networking/WiFi for detail of setting up networking.
