Okay so, I'm currently working on a final year project about vein visualization with Raspberry Pi 3 Model B+ and a NoIR camera V2. An infrared light source is required to capture clear vein image. I've tried connecting a 3w IR LED module with adjustable resistor to my camera board by it doesn't seem to work on NoIR V2. So I found an alternative for the IR light source as below. Is there any way that I can power this 24pcs infrared illuminator board using GPIO pins with pulse control through pwm? Thanks!
The specification of this board is as follows:
Product size: 44x17mm
Light light: Infrared
Infrared power: 2W
Waterproof: No
Input voltage: DC 12V
Current: 150mA
Structure: PC board
Light angle: 90 degree
Night vision distance: 20-30 meters
Wavelength range: 850nm
Adaptive lens: 3.6mm, 6mm, 8mm, 12mm, 16mm single board machine small lens.
LED cup angle: 15, 30, 45, 60, 90°
Compatible Shell: 50 Bullet Camera
