While trying the solutions suggested by a comment on my first question I tried to enable gadgetfs. I tried the following:
sudo modprobe dwc2
sudo modprobe gadgetfs
sudo mkdir /dev/gadget
sudo mount -t gadgetfs none /dev/gadget
But while executing the mount-Command, following error occurs:
mount: /dev/gadget: unknown filesystem type 'gadgetfs'.
Does anyone know why this happens?
EDIT:
Output of lsmod | grep gadget:
gadgetfs 24576 0
udc_core 49152 4 dwc2,libcomposite,gadgetfs,usb_f_hid
dmesg containing dwc2 or gadget:
[ 5.102521] dwc2 20980000.usb: 20980000.usb supply vusb_d not found, using dummy regulator
[ 5.102690] dwc2 20980000.usb: Linked as a consumer to regulator.0
[ 5.102716] dwc2 20980000.usb: 20980000.usb supply vusb_a not found, using dummy regulator
[ 5.323744] dwc2 20980000.usb: dwc2_check_params: Invalid parameter lpm=1
[ 5.326750] dwc2 20980000.usb: dwc2_check_params: Invalid parameter lpm_clock_gating=1
[ 5.332324] dwc2 20980000.usb: dwc2_check_params: Invalid parameter besl=1
[ 5.335372] dwc2 20980000.usb: dwc2_check_params: Invalid parameter hird_threshold_en=1
[ 5.423716] dwc2 20980000.usb: EPs: 8, dedicated fifos, 4080 entries in SPRAM
[ 5.425129] dwc2 20980000.usb: DWC OTG Controller
[ 5.425199] dwc2 20980000.usb: new USB bus registered, assigned bus number 1
[ 5.425277] dwc2 20980000.usb: irq 33, io mem 0x20980000
[ 34.182486] dwc2 20980000.usb: bound driver configfs-gadget
[ 171.860961] gadgetfs: USB Gadget filesystem, version 24 Aug 2004
lsmod | grep gadget? Also try reading through the output ofdmesgfor anything to do with dwc2 or gadget. – Fred Oct 03 '19 at 16:12modprobe g_mass_storage? – Fred Oct 04 '19 at 11:24
