Main Question: Can my raspberry pi (powered on it's own) determine if power is being supplied to the monitor (powered by a wall plug)?
I'm trying to determine the power state of the display that is connected to my Raspberry Pi 4.
The following was tried with force_hdmi_hotplug=1 inside /boot/config.txt
By default, I've had this option on inside /boot/config.txt
because a while ago I was testing this and without force_hdmi_hotplug=1
, reconnecting the hdmi cable would not actually turn on the display (the raspberry pi would stay in VGA mode or something).
I have tried using tvservice
, but it has not led to any good results. Using tvservice -M
(monitor), I found the following results:
- Disconnecting the display via the HDMI cable from the raspberry pi will yield no events being detected
- Reconnecting the display via the HDMI cable from the raspberry pi will yield no events being detected
Using tvservice -s
(status), I found the following results:
state 0xa [HDMI]
when connectedstate 0xa [HDMI]
when disconnected
The following was tried with force_hdmi_hotplug=1 NOT INSIDE (disabled) /boot/config.txt
tvservice -M
- Disconnected the display via the HDMI cable from the raspberry pi will yeild
HDMI cable is unplugged.
HDMI is attached
tvservice -s
state 0x9
state 0xa
However, disconnecting the monitor power cable with the HDMI still plugged in will yield the following two events simultaneously:
HDMI is unplugged
HDMI is attached
tvservice -s
will still yield state 0xa
and even using xrandr
will say that a display is connected. xrandr -display :0 --listmonitors
will still list a monitor.
Is what I'm looking for even possible?
