just a short scenario i want to use Raspbeery as a Wlan Repeater with a USB/Dongle Wlan Adapter because the internal has less Range.
Is there any chance to get this scenario to work? if so any help is welcome thanks in advance
Robert
canario
I think you can use this setup using Raspberry Pi as Access point as WiFi router/repeater, optional with bridge. Just search and replace all occurrence of wlan0 with wlan1 in that setup and it should do. Maybe you have also to correct the context on some places but that can only be formal changes provided the USB/WiFi dongle has at least the same hardware options than the built-in WiFi device. Otherwise the setup should be a good template to adapt it to your dongle anyway. Give me a comment to this answer if there are some problems.
  • 42,107
  • 85
  • 197
